I bought all of the gear except the tanks for learning OxyAcetelyne cutting. I got a great deal for everything for $50. A benevolent uncle gave me a quick and dirty tutorial and I cut some stuff and ruined some sweatpants. I love it. I already weld with MIG but wanted to be able to cut bigger stuff.
I would love to hear your tips and suggestions when learning to cut with this method. Do I need to worry about charts for tip sizes, things to look for or things to avoid.
I'll go hunting for some tutorial videos, but you guys always know so much and share so many great tidbits
Hobbyist MIG welder with 75/25 gas on a Lincoln SP-140 in my garage/workshop/gym/storage space. Very new and still learning.
"Service is the rent you pay for room on this earth" - Shirley Chisholm
We were just talking O-A in another thread in general. I like to refer to charts because I don't keep that stuff on the tip of my tongue. I use "Victory" type handle (300 series, heavy duty line) with welding/cutting/heating attachments, but there are many different types out there. So, what kind do you have? That is probably the single most important thing so you can look up charts to have a general idea of what you're working with.
Looks like the used kit I bought has Victor Brand torchs. I have a 100, 315 and what looks like a ST1600C (Big ass torch). Will there be a seprate chart for each one? My teacher/uncle said I should be fine with the smallest 100 gun since I'm doing mostly home projects and DIY stuff.
Rusty Steel cuts heaps better than brand new mill scale. The rust is the starting point of the cutting process.
I collected some PDFs from the internet into a Google folder, if you want to check them out.
Oxy-Acetylene Charts
You should be ok with the smaller 100 series, but they usually take the "3" series cutting tips, vs the "1" series of the heavy duty torches, so they may not interchange.
- ironshepherdforge
On the social media side, I'd recommend listening to the podcast for ICWeld's interviews. He is the master of the gas axe. #torchnorris
I'd also recommend following his Instagram @ICWeld and his YT channel. He does a bit of explaining, but for visual learners, his form is impeccable and so subtle you may miss key points until you've watched the videos a dozen times. I'd say try to watch it on a big TV rather than a phone so you can really see the details.
Part time blacksmith and bladesmith.
Instagram @ironshepherdforge
FB Iron Shepherd Forge
http://www.ironshepherdforge.com
Etsy Iron Shepherd Forge
Youtube ironshepherdforge
Lincoln 140HD, Everlast 160STH, LangmuirPro, Razorcut45
That's great. Youtube has so much. Just gotta know who is good and who to avoid.
I’ve used Victor, Smith and Airco torches cutting from light to very heavy materials. Both manual hand cutting and mechanized track machine cutting methods.
In my opinion, the most important thing (esp when learning) is learning how to properly set a neutral flame.
You don’t need to have a big roaring acetylene flame. Just nice and casual then neutralize with oxygen.
I'm going to assume this makes sense as I watch more and learn more. It sounds super important, but flame terms like neutral, acetylene and oxygen flames are lost on me right now. Thanks for the inputsnoeproe wrote:I’ve used Victor, Smith and Airco torches cutting from light to very heavy materials. Both manual hand cutting and mechanized track machine cutting methods.
True, cutting is a little bit different, but it's a great video to learn how to set up neutral-flames.
This one is also really good
-uPAjIOkLVA
In case I haven't linked it before, here is my Google Folder that has some charts you can print out as guides.
Oxy Acetylene Google Folder
-uPAjIOkLVA
Thanks for the links. Those are awesome!! And the videos too.Oscar wrote:True, cutting is a little bit different, but it's a great video to learn how to set up neutral-flames.
-uPAjIOkLVA
