Cutting a few inches off the end of some 4x8 16ga plate and the cutoff disc grabbed onto the end and threw a chunk of the disc right off. Good thing the guard was properly positioned. Launched the piece up into the guard and then straight down and away from my head. Not a huge chunk, but a great reminder about safety with these things!
- Chips O'Toole
Youtube is full of people using these things without guards. "I've been doing it this way for years, and I've never had a problem." Yes, that's how it works. You never have a problem, and then you have a problem.
Another thing: people think face shields are enough. If you look around online, you can actually find accounts of wheels going through people's clothes, into their bodies.
The only time this has happened to me, I was on the wrong side of the blade against its rotation. Something to bear in mind is the direction things are spinning when using them. Sometimes, you just have to get on the backside with the grinder to reach, but that is when it usually goes wrong.Spartan wrote:Cutting a few inches off the end of some 4x8 16ga plate and the cutoff disc grabbed onto the end and threw a chunk of the disc right off.
but something else caused it therefore its not a problem so it doesn't count, so i can keep on doing it like that.Chips O'Toole wrote:Youtube is full of people using these things without guards. "I've been doing it this way for years, and I've never had a problem." Yes, that's how it works. You never have a problem, and then you have a problem.
![Shocked :shock:](./images/smilies/icon_eek.gif)
sad to say i know people like that.
I used to use those flip down face shields, never really felt protected, I upgraded to one of these and I really like it.
https://www.amazon.com/gp/product/B088B ... UTF8&psc=1
- faceshield.jpg (18.44 KiB) Viewed 1932 times
Fame is vapor, popularity an accident, riches take wings. Only one thing endures and that is Character.
BillE.Dee
- BillE.Dee
[/quote] but something else caused it therefore its not a problem so it doesn't count, so i can keep on doing it like that.
sad to say i know people like that.[/quote]
Tweake, that's something like a brand new second hand almost used recap.
I've actually been grinding on something and to my side had a couple tubes get blown over in the wind and smash me on the noggin where the hard plastic is on the top of face shield.
To this day I think it saved me from a good couple stitches..
Not enough for me to go out and get a hard hat though, I just chain up my loose material now.
BillE.Dee
- BillE.Dee
just being around stuff, one should be aware of things that may happen. Being around MOVING items one should be more aware and do their best to prevent accidents.
bap,,,are you sure the ground wasn't shaking out there when the tubes fell???
