I would appreciate opinions on the best way to achieve long clean and straight cut on thick sheet material. I have a 40" shear, 7x12 band saw, carbide metal cutting circular saw, and plasma cutter. However, the shear can't handle anything greater than 16 ga material, and the other methods I listed either don't yield a clean cut or have a very limited width of cut. Anyone get good results without a massive hydraulic shear?
- ldbtx
I use a straightedge guide for my plasma cutter. Works great.
Larry
Larry
Miller Bobcat 225
Tweco Fabricator 211i
AHP AlphaTIG 200x
Lincoln SP-135+
Hypertherm Powermax 30 Air
ProStar O/A torch
AHP AlphaTIG 200x
Lincoln SP-135+
ProStar O/A torch
Farmwelding
- Farmwelding
Straightedge and the right amperage should get a fairly clean cut within a small constraint. Or a straight edge to ride your circular saw and go the right speed.
Instagram: @farmwelding
Nick
Nick
i use a morse 9" worm drive circular saw.
cuts up to 3/8" mild steel.
straight edge and your off the the races.
cut very cool and almost spark-less.
i think it spins about 2600 rpm
MK Morse CSM9MB 9-Inch Metal Cutting Circular Saw
+1ldbtx wrote:I use a straightedge guide for my plasma cutter. Works great.
Larry
Yeap, if you already have your plasma cutter all set-up, connected, air compressor filled, no reason to not grab the plasma torch. I just recently used a Powermax30xp at my school where we bought one for our Solar Car project----my very first time with a Hypertherm plasma, and my God that thing cuts awesome! Just practicing showing the students how to use it; it cut through 1/2" pretty darn easily! Makes my Eastwood look like a toy.
- ldbtx
I've got the Hypertherm Powermax 30 Air with the built-in compressor. Don't know what the pressure is, but it's always rightttreb4 wrote:ldbtx wrote:I use a straightedge guide for my plasma cutter. Works great.
Larry
What air pressure do you run?
Larry
Miller Bobcat 225
AHP AlphaTIG 200x
Lincoln SP-135+
ProStar O/A torch
AHP AlphaTIG 200x
Lincoln SP-135+
ProStar O/A torch
Check the tips of your plasma, as well as the quality of your air. If those planets are aligned, it will give a beautiful cut on steel.
