Coolidge wrote:By all means thanks!
Start with gas. 30 cfph. I use 1/8th cerriated tungsten. I sharpen to a point then ball by switching to max cleaning (ep).
Set your ac balance to 70 percent (en).
This takes some practice.
Pick a starting point and run your heat up. I have had others watch for me and I usually go up to about 180 amps. You will see your anodizing start to break down. The arc usually favors one side. Reduce amps until you see the arc wander to the other side and break down that anodizing. I know it sounds crazy but it works. Once both sides are melting add filler and hold the heat for another second, until you see it flatten out. Reduce the heat until the puddle freezes. Not completely off like some videos show. Advance about 3/4 of the last puddle, start increasing the heat and add filler. Hold the heat and let the filler flatten out again.
Repeat this process for each step. You will use less heat as you go. Let the puddle be your indicator.
Let me know how it works for you and if you have any questions.
