burnttoast
- burnttoast
Hello all, haven't posted in a while. would like to know anyone's opinion on what would be the most versatile to get. should I get a band saw, metal cutting blade for my circular saw, or a dedicated metal circular saw? right now I'm using cutting disc on my angle grinder, and it's making a mess in my garage with all the dust that it produces. Thanks
burnttoast
- burnttoast
BillE.Dee
- BillE.Dee
I have both the band saw and the porta band. With the band saw you can set it and basically walk away if the cut is a long cut, but I find that the porta band seems to cut quicker. Working on building a table for the porta band.
I went with this instead of a portaband, and man it rocks! I’ve cut 1/2” plate with it no problems, really good for 45ing tubing or unistrut. The makes a really clean cut too, even on 1/2” no burs, just a touch of a flap wheel after and it’s prefect. 2 1/4” depth of cut. Since it cuts so cool it doesn’t discolour stainless like abrasives can.
Downsides are it’s LOUD. When that blade touches metal it screams! And the blades aren’t cheap and don’t last forever. I believe I paid $45-$55 apiece for Irwin blades.
I have a 4” Jet bandsaw and it’s not very good. Hard to square; make that “impossible.”
I use it in a vertical position with a table i made but even that is so so. Briefly, I am very disappointed.
Anyone tried a sawzall? What blade for 1-½” tubing with 1/16” wall thickness? Probably easy tl make a jig for it for repeatable cuts
HTP Invertig 221H w/ Arctic Chill cooler and CK20 torch
Lincoln MP210 -- SOLD
Optrel Crystal 2.0
Optrel Crystal 2.0
You need more then one tooth for a given material thickness, so for 1/16" at least 18TPI, 24 may be better if you're doing a lot of cutting.koenbro wrote: Anyone tried a sawzall? What blade for 1-½” tubing with 1/16” wall thickness? Probably easy tl make a jig for it for repeatable cuts
From this website
How Many Teeth?
In determining teeth per inch (TPI), try to find a balance finish and feed rate. Blades with more teeth cut slower and smoother. Blades with fewer teeth cut faster, with slightly rougher finish.
For any kind of precision cutting, the rule of thumb is to always try to keep at least three teeth in the material at all times. This adds stability and accuracy and applies to cutting in both metal and wood.
Use coarse tooth blades (2 or 3 TPI) for re-sawing and cutting thicker materials. For general wood cutting duties in typical 3/4″ material, use a 4 TPI blade for coarse, fast cutting and a 14 TPI blade for slower, smoother cutting. A blade in the 6 to 8 TPI range provides good general-purpose performance. This same equation applies whether you’re cutting wood or metal. For thinner metals and plastics under 1/4″ use an even finer blade (18 – 32 TPI).
with band saws you need to use good blades otherwise it will never cut straight.
found out the hard way when i was cutting stainless tubing. cuts starting going way out. then found out the blades where not bimetal. when the blades start going blunt the cut starts to wander.
of course poor cuts means poor fit up and makes welding a pita.
koenbro wrote:I have a 4” Jet bandsaw and it’s not very good. Hard to square; make that “impossible.”
I use a hackzall all the time for tubing, slicing off bolts, etc. Even up to 1/4” flat bar I’ll consider it. 18 TPI blades are a good all arounder for me. The narrower ones are great for cutting circles. Or I’ve used em quite a bit for making square holes for carriage bolts. They do cut a lot better than most people think.
t
- SlowTrafcKpRht
I have a hortz bandsaw, and obviously the variety of angle grinders. I enjoy much better the hortz bandsaw... It's cleaner, easy for straight cuts, and doesn't throw sparks/metal like my angle grinder. I'd like a chop saw, but it seems so aggressive and throwing spars/metal everywhere. I just don't want the extra mess to clean.burnttoast wrote:Hello all, haven't posted in a while. would like to know anyone's opinion on what would be the most versatile to get. should I get a band saw, metal cutting blade for my circular saw, or a dedicated metal circular saw? right now I'm using cutting disc on my angle grinder, and it's making a mess in my garage with all the dust that it produces. Thanks
I'll say, my hortz bandsaw is very temperamental... The adjustments for straight cuts is a huge pain. I'll fully admit this all could be me and the setup. Yet, doubtful... Yes, it's a horror fright bandsaw with a few upgrades. I've had it for nearly 2 decades. I'm way open (pm) for advice... Could a better quality bandsaw eliminate this pain adjustments?
Anyway, get a quality portable bandsaw you'll never go wrong.
What he said.LtBadd wrote:AbsolutelySlowTrafcKpRht wrote:[Could a better quality bandsaw eliminate this pain adjustments?
I’ve never had to adjust mine, at all. I was getting wonky cuts when it was still new but that was with the cheapy blade it come with. Switched it out to a good quality blade and it cuts really straight. I’ve cut a 12” tall pieces of steel plate, clamped vertically in the vice, and get a near perfectly straight cuts.
Good blades make a huge difference!
- SlowTrafcKpRht
Yes, agreed about the blade. I've tried several, I think this one now (longest lasting) is a bosc...
What are you or anyone else using?
I use a bi metal blade, depending on what your cutting depends on the TPI you need, see my previous post in this thread for more info. Blades also require a breaking in period for longest life.SlowTrafcKpRht wrote:Yes, agreed about the blade. I've tried several, I think this one now (longest lasting) is a bosc...
