Jim Bridger
- Jim Bridger
I'm still a newbie here, but I think I'm ready to breakdown and buy a drill press. The more work I play around with the more frustrated I get simply using a hand drill. My question is what are people's recommendations for a reasonably priced bench top drill press. I'd prefer to stay within a budget, but obviously interested in whether the $150-200 types presses I see for sale can last and perform accurately. I'm a hobbyist but at the same time the reason I even picked up learning to weld was to help in fixing things on the farm we run.
Its definetly a good investment, it'll save you a lot of money in drill bits. Best way to drill steel is slow speed with a steady consistent heavy down pressure. Which is really hard to do with a hand drill. The right speed and feed rate, along with keeping the drill bit cool can get you hundreds of holes without needing to sharpen.Jim Bridger wrote:I'm still a newbie here, but I think I'm ready to breakdown and buy a drill press. The more work I play around with the more frustrated I get simply using a hand drill. My question is what are people's recommendations for a reasonably priced bench top drill press. I'd prefer to stay within a budget, but obviously interested in whether the $150-200 types presses I see for sale can last and perform accurately. I'm a hobbyist but at the same time the reason I even picked up learning to weld was to help in fixing things on the farm we run.
Which drill press you get heavily depends on
That being said, my next drill press will be this 1.5HP beast, which I can pick up at Northern Tool about 2 hours away.
https://www.northerntool.com/shop/tools ... _200659141
Closest competitor is a Grizzly with a 1.5HP motor for over $750 shipped. I have a Smithy Midas 1220LTD lathe/mill, and it's sturdy, but even it only has a 3/4 HP motor.
- the side of the part you intend to drill
- the diameter of the hole you intend to drill
- and/or how quickly you want to drill the part.
