Well, this is embarrassing. I bought a gas outfit a year ago, and it sat while I waited to find cheap tanks. I finally gave up and bought new ones. I built a cart for propane and oxygen, thinking I had bought a propane outfit plus additional stuff for acetylene. In reality, it turns out I bought an acetylene outfit with some additional stuff for propane.
Now I have to get a propane regulator.
The outfit came with Victor ESS42 regulators, so I looked for an ESS42 propane regulator. I found two flavors: 150 psi and 60 psi. I have no idea which one is right for me. I'm just a hobbyist with a 125-c.f. oxygen tank and a barbecue tank for propane.
A little help?
- Chips O'Toole
- Chips O'Toole
Now I'm reading I can use the acetylene regulator after all. I connected it to the tank with an adaptor.
I have a Victor CA2460 torch body. Looking to see what kind of propane stuff I need on the end of it.
Sadly, a mouse made a home in the coiled hose before I took it out of the box, so now it smells like infected mouse crotch.
Hi Chips, I'm in the midst of doing the same thing and have the same torch.Chips O'Toole wrote:Now I'm reading I can use the acetylene regulator after all. I connected it to the tank with an adaptor.
I bought a propane specific tip for the CA2460, a GPN-1 if my memory serves me.
David
Millermatic 130
Primeweld 225
Millermatic 130
Primeweld 225
- Chips O'Toole
Help! I can't figure out what size heating tip I need. The acetylene tip included with the kit is size 8.
I want to be able to bend stuff and heat cast iron parts prior to welding. Right now, I have a 15"-wide piece of 1/4" plate, and I want to heat it red hot so my finger brake will bend it.
This is a propane compatible #8Chips O'Toole wrote:Help! I can't figure out what size heating tip I need. The acetylene tip included with the kit is size 8.
https://weldfabulous.com/victor-0323-03 ... gle-stage/
That said, have you tried the one you have?
David
Millermatic 130
Primeweld 225
Millermatic 130
Primeweld 225
- Chips O'Toole
Thanks. Not cheap, is it?
I have not tried it. The tip I have is for acetylene, and I have no idea whether it will do propane.
- Chips O'Toole
Definitely not cheap.
I priced out what it would cost to get the "proper" propane tips for my torches and I was looking at near $500. That's a heck of a lot of acetylene!!!
David
Millermatic 130
Primeweld 225
Millermatic 130
Primeweld 225
- Chips O'Toole
Chinese tip is $40.
I am looking around, and I see a guy claiming the only difference between acetylene and propane heating tips is a little rim that protects the propane flame. Heck, I can thread an acetylene tip and make that.
- Chips O'Toole
Tried the acetylene tip. Does this look right?
I read you can clamp a piece of metal around it to shield the flame for propane.
Guess I'm an expert now. If any of you kids need tutoring, I am here to help.
- 09 22 20 acetylene heating tip running propane unmodified small.jpg (196.64 KiB) Viewed 2712 times
That’s looking like a flame alright.Chips O'Toole wrote:Tried the acetylene tip. Does this look right?
Is that with o2?
David
Millermatic 130
Primeweld 225
Millermatic 130
Primeweld 225
- Chips O'Toole
That was with O2. Not sure what a heating flame should be like. I tried to get a nice blue flame that looked intense and didn't flap around too much.
- Chips O'Toole
I'm going to try to char a steak with it.
For heating you have two options. Blue and orange. There’s a technical term. Carbarizing ??? Can’t remember. Orange is a lower heat and won’t impart carbon to the metal. Blue is hotter and may potentially add carbon to your metal if you get it hot enough. I may be backwards on the carbon point but Know im right about the temp.
- Chips O'Toole
I fired up the acetylene rosebud today, and I used it to bend 1/2" steel tabs on a middle buster. I had no problems with it, which makes me wonder if something is wrong.
- 09 27 20 middle buster with tabs bent using propane torch small.jpg (161.59 KiB) Viewed 2494 times
- Chips O'Toole
I don't know. It was powder coated.
