Of my many projects, I would like to build a down draft table to use for torching, plasma, grinding and welding. I would like to see if anyone has made one or has some ideas on making one. I know Jody has the series on his down draft, and I would probably would make it very similar to that.
Heres an idea. Go to Lowes and get one or two of the inline fans that they sell for $25-$30 and use those instead of buying an expensive exhaust system. You cal also get a bunch of the flexible ducting the same size for a few bucks extra. I do this for when I'm in more or less open air conditions but still need to get dust or smoke away from my work area. Prolly not OSHA approved but just a thought.
Be the monkey....
We must be on the same wave length
I went to Home Depot and looked at their inline fans. I thing I will use one for a hood in the garage. You are probably right, it might not be OSHA approved at the shop but its fair game in the garage
Last edited by Superiorwelding on Mon Mar 31, 2014 7:30 pm, edited 1 time in total.
I like the logo!
If you're looking for downdraft JUST for cutting, and high velocities are not an issue, check your local junkyard for a 110V squirrel-cage fan from a mobile-home furnace. You can move a ton of air with one of these on the cheap.
Steve
Oops didn't mean to load that logo.
I have a squirrel cage from my old furnace that would probably work and then some.
- Wiredwelder
@nickn372 I did the same thing on my kitchen exhaust, several fans in series work very well! It's all about keeping the air speed up! I used 3 fans. I had 2 and got one more , liked it so we'll I kept it that way.
