It's been a while since I've posted on the forum. (OT at work, AWS school, new house, etc.)
I am on 4G plate at school and it is kicking my.....
My root is good as well as the hot pass. It's when I get to the stringers that I (and I know it's me) have issues.
Here's the set up:
5/8" plate w/37.5 degree V
1/8" 6010 root
3/32" 7018 hot pass and stringers
100-110A
Here's where everything goes south:
After the hot pass, I start my fill stringers. I've tried dragging, whipping and weaving. I've tried positioning myself in different places and angles to see the puddle better (I'm 6'3" and the test tree is not). No matter what, they all look like.....
I know nothing replaces practice AND I'm just now learning, but this has me aggravated. I picked up on the other three so well and fast (I've passed the bend tests for 1, 2 and 3G), but this one has me pulling my hair out. We've been in class for only 9-10 weeks with 25 more to go.
ANY advice and tips would be greatly appreciated.
- RocketSurgeon
Are you keeping the 7018 pushed right up in there? And rod angle about straight in?
Common problem is to forget to continuously lift your hand - when the weld is flat, gravity helps your hand drop naturally - for overhead keep pushing up.
100 amps and keep the flux lightly dragging on the plate should get it done - but not until you practice overhead on scrap until it feels natural. Then try the plate test.
Good luck and have fun
Edit: I forgot, never whip 7018, straight drag or weave only.
- RocketSurgeon
I do keep a short arc w/o sticking. No more than a 1/16". I keep a slight pull angle or straight rod. Never pushing the puddle.MinnesotaDave wrote:Are you keeping the 7018 pushed right up in there? And rod angle about straight in?
I haven't tried dragging the flux though. I have class tonight and will try that.
Looking straight down the groove (pulling the puddle towards me) seems more comfortable than across.
Thanks for the tips, Dave.
Chris
AWS D1.1, D17.1
AWS D1.1, D17.1
Chris,
I prefer a very slight "push" on overhead stick. 5* for a groove, 15* for a fillet. (Estimates... It's been years since I thought about it.) Yes, with enough amps that the flux is dragging a bit.
Try it all, and you'll find what works for you.
- RocketSurgeon
The first thing I did tonight was make myself comfortable in order to be propped up and steady. I sat on a 5 gallon bucket and lowered the clamp arm to a reachable/workable level. I could see the whole groove and bead. I ran the root and hot pass without any problem. I ran two fillet passes that were 10x better than the grapes I was making before. My two stringers were clearer to me from the position on the bucket and just came to me easier.
Tomorrow night I'll sit my 270lbs. behind on that bucket and finish the stringer caps.
Chris
AWS D1.1, D17.1
AWS D1.1, D17.1
Hey, Rocket,
Have you watched Jody's video on 4G 7018?
If not, it should help you a ton. https://www.youtube.com/watch?v=Gdm23KLTEW0
- RocketSurgeon
I did. It helped. I found a way to steady my hand: a five gallon bucket.AKweldshop wrote:Hey, Rocket,
Chris
AWS D1.1, D17.1
AWS D1.1, D17.1
- RocketSurgeon
Update:
I've taken everyone's tips and advice and used them to my advantage and betterment. If I can make one more good weld, my instructor will put it on the bender.
Then, he said, I have to make another 3G and 4G for bend tests to be sure I have the technique down. If so, I can move on to Flux core and MIG.
Thanks everyone for your help.
Chris
AWS D1.1, D17.1
AWS D1.1, D17.1
- RocketSurgeon
Apparently, those cheap 5gal buckets from the local home improvement stores come in handy...for setting your keester on in order to steady your hands while running an overhead bead.
Seriously.
I sit on one, which brings me low enough to prop my left arm on the work table and steady my right hand. I'm 6'3" and the arm only goes to my chin. That made it awkward to see the weld.
Also, to watch my rate down the bead, I skewed the coupon slightly so I can pace the bead as I lay it in the groove.
I re-watched Jody's overhead 7018 video to get the right idea of how he manipulated the rod down the groove. Keeping a short arc, slight pull angle and keeping up with the rod as it burns shorter.
It just came to me after I put all of that together.
Seriously.
Chris
AWS D1.1, D17.1
AWS D1.1, D17.1
- RocketSurgeon
My instructor wanted me to finish my last 4G tonight, so he could bend test it.
I PASSED! Both sides!
He immediately put me on the qualifying tests: 2, 3 and 4G on .375 plate.
Feeling REALLY good.
Chris
AWS D1.1, D17.1
AWS D1.1, D17.1
- RocketSurgeon
plain ol Bill
- plain ol Bill
Once you pass the test's then you can start to work on becoming a welder. It feels good to make the test doesn't it? Now ask yourself if you can make the same weld with it tacked under the bench, up next to the wall, with not enough overhead clearance to be able to roll over.
Tired old welder
CNC plasma cutter
Colorful shop w/
CNC plasma cutter
Colorful shop w/
- RocketSurgeon
More tests before the course is over. 5G & 6G pipe, TIG, Al, etc.plain ol Bill wrote:Once you pass the test's then you can start to work on becoming a welder. It feels good to make the test doesn't it? Now ask yourself if you can make the same weld with it tacked under the bench, up next to the wall, with not enough overhead clearance to be able to roll over.
Chris
AWS D1.1, D17.1
AWS D1.1, D17.1
- RocketSurgeon
I finished the 2, 3, and 4G plates and cut out samples.
I passed those too!
On to MIG!
I passed those too!
On to MIG!
Chris
AWS D1.1, D17.1
AWS D1.1, D17.1
Boomer63
- Boomer63
You will do fine at MIG! Remember, don't take it too lightly! Hold the toes of the weld when in the V-Groove. Wait for the puddle to fill in and completely wet out before you move!RocketSurgeon wrote:I finished the 2, 3, and 4G plates and cut out samples.
I passed those too!
On to MIG!
- RocketSurgeon
It's been more than a week on MIG and I just have this to say:
4G position plate (open root) is a pain. Not as much as using Bernard guns in 4G position. They are HEAVY! (ow ow ow)
Chris
AWS D1.1, D17.1
AWS D1.1, D17.1
Chris,
Do they let you keep your coupons after they're bent?
It would be fun to etch them, post-bend...
- RocketSurgeon
I have all of my bend test straps. I keep forgetting to bring them home and etch them. I've been real curious to see how well I'm penetrating.
Chris
AWS D1.1, D17.1
AWS D1.1, D17.1
- RocketSurgeon
Monday, I get to test on 2, 3 and 4G MIG!
Chris
AWS D1.1, D17.1
AWS D1.1, D17.1
