Thiago469465
- Thiago469465
Im a beginner welder, and just getting into the welding field, these past few weeks I have been creating a small journal guide for settings of different types of welds and thicknesses. Are you allowed to bring one of these to a test or should I just try and remember everything.
KEEP THAT JOURNAL!!! I wish I would have done a better job of recording my welds from the past.
As to your question, I have not heard of anyone not allowing you to look at a little book of settings. Might impress your potential employer as well.
rohitmehta
- rohitmehta
That’s a big yes to keeping a journal for welding settings. Note about gas and tungsten, wire, welding sticks etc. And I would go so far as to say that if you become a good tradie
And are proud of your work then you should keep some record of what you leave behind you. brackets and such will come and go but critical and any structural welds keeping a diary is great idea. It is some times called an ACE.
Arse covering exercise.
After a while you will remember basic parameters/settings for different stuff and that will be a good start. Welding Machines vary as well, notes set yourself up to kick goals.
If you are beginning then maybe honest feedback would benefit more than a test. Tests cost money and assume competencies, skills however come by stuffing up things and learning better ways. Having a go around other good welders is almost always a good start. IMO
Amen to that. I have seen a small pocket note pad become a CYA legal document that literally was the difference of millions of dollars. US dollars for inflation reference.
