What causes porosity in welds?
The most common, to the real odd ball stuff, that gets overlooked during set up, before welding starts
Greg From K/W
- Greg From K/W
If your using welding rods then dirt and rust will cause it. As well as oil and grease. Water saturation in the coating on the rod.
If your talking about mig welding dirt on the base metal could do it. Rust might but you never know. Lets wait and see what the others say about it.
BlackCatBonz
- BlackCatBonz
Arc length too long, dirty material, bad techniqueebranden wrote:What causes porosity in welds?
Shawn Bailey
Sprinklerfitter Guru / Steamfitter Apprentice / Welder
TheExpert
- TheExpert
Porosity in welding is a result of dissolved gases or gases released during the welding process, being trapped in the metal when there is insufficient time to escape prior to solidification.
another big cause of porosity is cold starts! what i mean is striking an arc and moving forward too quickly. when u strike,you need to wait a second for arc to stabilize,then move your rod in a circular motion in place a couple times and then progress. this should prevent any chance of creating porosity.
