joshuanaaa
- joshuanaaa
Im welding 2inch schedule 80 carbon steel, 1/8 309 stainless filler metal, argon purge and shielding gas, tight 1/8 gap for root. If you have any tips, tricks, or set up info on this process please respond. THANKS!
Nice welding Joshua?
Are you sure you need any help
John
John
I can't believe it!
Two guys needing help on this test in a very short period of time.
Not to mention, Jody just made a video on that test.
here it is, part 1 and 2
http://welding-tv.com/?p=5265
http://welding-tv.com/?p=5271
If Joshua sees this, I hope it helps.
Good luck,
~John
Good luck,
~John
