WELD TEST
Posted: Tue Jul 14, 2015 10:37 am
by philsdeuce
If a welder qualifies on a plate test, using 1G position, what size pipe is he certified to weld on?
Re: WELD TEST
Posted: Tue Jul 14, 2015 1:17 pm
by kripl88
Not to sound like an ass but is that a serious question? A plate test will only qualify a welder to weld on plate. It takes a pipe test to weld on pipe
Re: WELD TEST
Posted: Tue Jul 14, 2015 4:02 pm
I believe a plate can only be used to simulate pipe in the matter of procedure qualification. For ease of set up. Not for welders qualifications
Re: WELD TEST
Posted: Tue Jul 14, 2015 4:28 pm
by MinnesotaDave
I've read a few times that 3G and 4G can qualify a welder for structural and pipe 24" diameter and up.
Here is one quote: "Most codes allow a welder to take a combination of the 3 and 4G positions, which typically qualifies the welder for all position structural welding plus pipe that is a minimum of 24 inches in diameter"
From this listing:
http://www.metalwebnews.com/howto/weldi ... cation.pdf
Can anyone verify this?
Re: WELD TEST
Posted: Tue Jul 14, 2015 7:46 pm
by kripl88
As far as I know, plate can be used to develop weld procedure tests but not individual qualifications. A 1" plate test can qualify a weld procedure to through most sizes and thicknesses but the usual test for a welder is the 2" xxx heavy wall in a 6g position to qualify all sizes and thicknesses.
Re: WELD TEST
Posted: Thu Jul 16, 2015 3:36 pm
by Superiorwelding
According to AWS D1.1 Structural Steel Welding Code, a 1G, 1" thick test plate will qualify you for 1/8" to unlimited groove and unlimited fillets as well as 24" O.D. pipe groove and unlimited fillet.
Re: WELD TEST
Posted: Thu Jul 16, 2015 5:43 pm
by plain ol Bill
Been over the hill and down the road to see the elephant more than a few times and you learned me something! Hope I don't ever need the info but now I've got it just in case.
Re: WELD TEST
Posted: Mon Jul 20, 2015 1:06 pm
by Boomer63
Phil - You are good 24" and up. But take the 6G. If you can pass a 2G and a 3G you can pass the 6G. If you can do the open root!
need advice for a standard 1104 down hill welding procedure
Posted: Tue Aug 18, 2015 5:18 pm
by BradlyD903
an anyone give me advice for down hill welding with 1104 down hill stick welding + Amps "heat" for each specific rod used from a 6010 1/8 - 5/32" and 3mm for underground pipe with a bead layout diagram for stacking welds from root-fill & cap?
It will vary to what machine I'll be using but my guess its a 8bank in this test shop because its a single hand welder position opening. "But you never know what machine it may be"..
help needed.
I'm a up hill lo-high welder have been for several years, looking to take a test for a standard down hill procedure. I Dont have the rods to use or someone to give me a clue.
