BR300
    Fri Mar 12, 2021 1:41 pm
Can anyone recommend a good welding helmet where I can wear a 3M Respirator 6291 under the hood. Looking for something in the $300-$400 range. I was looking at the Lincoln VIKING 3350, but Lincoln said they weren’t sure if the hood would hit the respirator, then they gave me a link to their PAPR helmet. Can’t afford $1500 for a helmet. I’m a hobbyist and new to welding.
Thanks!
    Wed Jan 22, 2014 12:00 am
    Connecticut
I have the Lincoln Viking 3350 and I wear a 3M 7500 respirator with the pancake filters (2297 I think??). It fits fine for me under the helmet. Plus with the 7500 at least, the down draft exhalation keeps my lens from fogging up.
Multimatic 255
    Thu Dec 26, 2013 12:41 am
    Laredo, Tx
I use my 3M 7075 respirator with 2297 pancake filters under my Optrel Crystal 2.0 and Panoramaxx CLT. On the Panoramaxx I do have to set it a bit further away from my face since the respirator can touch the helmet if Iset it too close to my face. Also works on my Optrel e684 since the shell is basically the same as the Crystal 2.0. All of them are top-notch welding hoods.
    Mon Feb 26, 2018 1:52 am
    Idaho
I've got a Miller Digital Elite (Miller equivalent to the Lincoln). It fits a 7500M with 2097 just fine. I also like to have a lincoln leather bib attached to the hood. That basically ensures that even if the respirator is touching (which is isn't) I won't get arc light coming from underneath.
BR300
Thank you all for the great advice!! Very helpful!
JWC
  • JWC
  • New Member
    Wed May 12, 2021 5:33 pm
    Lorton VA
I also used a Viking 3350 with a 3M respirator but cant tell which model it was. Probably one someone else already mentioned. Nice hood and respirator combo, but I haven't used some of the really expensive hoods. I did like the Viking 3350 a lot though.
pavetim
    Sun Apr 03, 2016 11:10 pm
Idk I have the whole lin on papr system with the 3250FG helmet and I'm pissed I can't even use it for tig in past 3 days at school I have been flashed like 30 times And I'm not using like 20 amps I am using like 80-140 amps. I emailed Lincoln and their response was recommend buying the 3350XG. So spend $3200 on a papr and now another $900 in a helmet. Lincoln lost me right then and there. Hope it's better I ordered a miller infinity 4X hell I put on my harbor freight helmet yesterday and it doesn't flash me like the Lincoln one does. Very disappointed and pissed
tweake
    Mon Dec 18, 2017 4:53 am
    New Zealand
is it setup correctly? usually sensitivity setting and delay. sometimes people set them less sensitive to avoid sun light or shop lights triggering it, but then have issues with arc triggering it. usually have the delay long enough to be annoying.
no dirt blocking the sensors? film on the front?
new battery?
