G-ManBart
    Sat Aug 01, 2020 11:24 am
And256 wrote:
G-ManBart wrote: One of the true experts who has posted on most of the welding forums once did a writeup about welding with wet 7018 rods. He soaked old rods in a can overnight to get them completely saturated, then used them. He would pull one out of the can, put it in the stinger, stick the rod to the work and let it cook until the steam would release, then break it free and weld a perfect bead. He did cut and etch as well as bend tests and they were perfect.
According to what I read about them they shouldn't even start. But if they passed a bend test I'm fine.
What's the member's name? I would like to read some of his posts.
As MinnesotaDave mentioned, it was CEP who posted that on Welding Web and I think shared it on the Garage Journal Forum as well. I haven't seen him post in a while, but he helped me a bunch when I was first starting to learn how to weld (still learning!).
Here's at least one of the discussions:
https://weldingweb.com/vbb/showthread.p ... 1-Wet-7018
Miller Millermatic 350P
Hobart Champion Elite
Everlast PowerTIG 210EXT
FWE
  • FWE
  • Active Member
    Sat Jan 16, 2021 12:29 pm
    Scotland
Ha, thanks for the link!
Just found these again while looking for something else, if anyone is interested, some tables that show thickness limits in relation to preheat, hydrogen and material composition. Taken from BS EN 1011-2:2001, worth a read if you are interested in weldability of steels. Can skip straight to the the appendices, which are three quarters of the document, for the interesting stuff...
No Preheat
No Preheat
Screenshot from 2021-02-19 20-54-42.png (32.6 KiB) Viewed 13677 times
Creep Resistant
Creep Resistant
Screenshot from 2021-02-19 20-56-03.png (76.53 KiB) Viewed 13677 times
Low Temperature
Low Temperature
Screenshot from 2021-02-19 20-58-25.png (48 KiB) Viewed 13677 times
And256
    Tue Feb 09, 2021 8:52 am
G-ManBart wrote:
And256 wrote:
G-ManBart wrote: Here's at least one of the discussions:
The last post there was from 2013.. was :lol:
And256
Coldman wrote:Mild steel is not but hydrogen rich welds are. That's one instance you need low hydrogen rods, mig or tig processes.
So mild steel does not have a problem under these cold temperatures but any kind of no low-hy welding may cause shattering problems?
MIG and TIG are low-hy processes but it is rarely mentioned.
Coldman
    Mon Dec 15, 2014 2:16 am
    Oz
Not so much shattering. Cracking is the risk. Used to manufacture meat carton freezing tunnels and spiral freezers operating at -40degrees and below. All standard mild steel sections but all mig welded.
Interesting to note regarding refrigeration pipework (ammonia), at around -30 degrees C we have switch from the normal A53B/A106b pipe to A333/A334 low temp rated pipe.
Coldman
    Oz
Never seen it myself but I was told a 6010/6011 weld at low temp would break if hit with a hammer particularly if layed down hand.
And256
Thanks for the info.
Coldman wrote:Never seen it myself but I was told a 6010/6011 weld at low temp would break if hit with a hammer particularly if layed down hand.
From what I've read 6010s are much stronger than 7014s at cold temperatures.
Of course, 7018s are far stronger than 6010s.
    Sat Feb 17, 2018 10:10 pm
    Carberry, Manitoba, Canada
You're saying an Er70 mig or tig weld is considered a low hyd weld??
tweake
    Mon Dec 18, 2017 4:53 am
    New Zealand
correct.
tho its hard wire mig that low hyd.
the moisture in the flux of stick or flux core is where the hydrogen comes from.
Coldman
    Oz
Mig and tig are low hydrogen processes.
tweake wrote:
JayWal wrote:
And256 wrote: So mild steel does not have a problem under these cold temperatures but any kind of no low-hy welding may cause shattering problems?
correct.
Gotcha. Did not know that.
FWE
  • FWE
  • Active Member
    Scotland
Did you know that, in general, plasma arc welding uses 2% to 7% hydrogen in the shielding gas? Learn something new every day, or I do anyway...
sbaker56
    Sat Feb 08, 2020 12:12 am
Something to keep in mind, there isn't any voodoo that happens when a 7018 picks up some moisture as compared to a 6010 for example that has moisture in the flux and actually weld like crap if the flux dries out. In other words, a moisture stricken 7018 isn't going to be any more prone to hydrogen cracking than a fresh 6010, 6011, 6013 etc right out of a sealed can.
I may be mistaken as it's been a while since I've looked into it, but I also believe hydrogen cracking is more of an issue with low alloy/higher strength steels. Plain mild steel IIRC generally doesn't suffer from hydrogen embrittlement.
Just how exposed to moisture they are will make a difference though, I can tell you first hand that an open cardboard box of cheap 7018s that has been sitting in a truck for a year down in the south will weld like crap, you'll often get constant pinholes through the entire weld. Generally moisture resistant brands of 7018 will hold up a lot better when left out in the open.
