I will look into those links tomorrow if I do end up buying a welder for practice it will most likely be used unless I win the lotteryLouie1961 wrote:Trying to do a solid for a fellow nutmegger. Hate to see a young guy in school spend more than he needs to.
Stick_Welder_Steve
- Stick_Welder_Steve
True but only for large output. I run my Airco on a 60 amp circuit up to 230 amps AC tig.soutthpaw wrote:Louis, You forgot to add and the power to run it. . 100 amps for most transformers.
Sent from mobile. Not responsible for Typos
My Dialarc 250 usually runs on a 50 amp breaker - for 1/8" and 5/32" electrodes I've had no problems.
soutthpaw
- soutthpaw
Yeah they seem to do okay to 5/32. The 330ABP/Airco is power factor corrected so it needs a lot less juice than say a Dialarc unless it's the HFP version. You get about 165 more amps over a Dialarc for about the same power draw.MinnesotaDave wrote:True but only for large output. I run my Airco on a 60 amp circuit up to 230 amps AC tig.soutthpaw wrote:Louis, You forgot to add and the power to run it. . 100 amps for most transformers.
So what? I just checked the Lincoln and Miller web sites for the owner's manuals. The Idealarc and the Dialarc both draw a max of 73 amps...not a huge difference. Lincoln recommends wiring with 8 gauge conductor and Miller recommends wiring with 6 gauge conductor. Breakers are cheap, it is the wire that makes a 240 volt circuit expensive. In either case, 8 gauge or 6 gauge will not break the bank. Most dryer circuits are wired with 10 gauge, and most range circuits are wired with 8 gauge. Either would get him by, he just couldn't crank it up to 250 amps, which he probably doesn't need to do for his intended purpose.Louis, You forgot to add and the power to run it. . 100 amps for most transformers.
Everyone seems to think you have to use 1 gauge or 2 gauge wire for a 100 amp circuit, but that isn't the case for a dedicated welder circuit. The electric code allows for overrating the breaker size relative to the conductor size depending on the duty cycle of the welder. Plus, if you don't max out the welder, its probably not an issue anyway. I ran my Syncrowave on a 50 amp breaker, up to ~200 amps for a long time with no issues.
Multimatic 255
Not for stick welding.
I ran my 2 Idealarc 250s and SW250 on a 50amp 230 line and was able to weld 250-300amps just fine.
Stick_Welder_Steve: Here's another good one...good price http://albany.craigslist.org/tls/5381153761.html
A bit of a drive, see if he will knock off $100 for gas money
Multimatic 255
fmagalhaes
- fmagalhaes
To answer your question.. I will be welding up a steel Sailboat about 40 feet in length. I was leaning toward the Miller Thunderbolt AC/DCAKweldshop wrote:Merry Christmas to you.
What kind of welder are you looking for?
What stuff are you gonna weld?
Any advice from you old salts out there is welcome.
Many thanks from a Rookie
