First of all, someone else, besides myself, started to take this repair on. One side of the boom is completely broken off and a bevel was ground on both the parent and the broken piece. The bevel grind is completely wrong, about 45°, on both front and back sides. To much metal was taken off the most part of the mating surfaces that when the piece is lined up, or in it's proper place, there is as much of a gap between the two mating point as 3/8". The length of the break is approx 10" long.
My first thoughts was how in the world am I going to get a good root weld in that? Can I use a filler? Do I use pieces of the parent metal or de-fluxed rods that I'll be using?
I don't want to use pre-heat and long post cool for this job, the boom is just to big. I'd like to use the cold weld method, weld one inch, peen, move to another location and do the same, keeping the parent metal cool enough to touch. (I know, It's going to take a long time.) I'd like to use stringer bead for the whole job, no weaving. My boom will be flat for all welding positions, no verticals.
I chose the 321-16 rod over Nichol or the 7018 to do this job. Although this rod cost a lot more, I think I'll have better success in this situation.
There is probably some details you may want to know that I left out...if so....please ask.
Any help or ideas will be greatly appreciated.
