ryanjames170
- ryanjames170
what exactly is haynes multipass electrodes
Welder/Fitter
RM Fab & Products
Lincoln Invertec V300 pro
Miller 54D Wire Feeder
Miller 2E DC Welder Generator
Everlast Power IMIG 200
Everlast Power ARC 200ST
RM Fab & Products
- Farmwelding
Are they just hardfacing rods?
ryanjames170
- ryanjames170
i have no idea really i know there 115,000 PSI tensile Hardness of Rc28 and are able to to multipassFarmwelding wrote:Are they just hardfacing rods?
they are also low hydrogen and are a ideal base for hard surfacing , and can be built upto heavy thickness with out cracking
but there composistion is close to hobarts M-932
but beonde that i really dont know exactly what they are..
Welder/Fitter
RM Fab & Products
RM Fab & Products
I think you answered your own question. They are a transition rod between, say, a36 carbon steel and a true hard-facing. Build as much as you want at a medium hardness, then put a few layers of the hard stuff on top. The transition between the a36 and Haynes won't crack for their similarities, and the transition between your Haynes and a serious high-Rockwell rod won't crack for the same reason.ryanjames170 wrote: ...and are a ideal base for hard surfacing , and can be built upto heavy thickness with out cracking ..
This is not gospel. This is guesswork.
Steve
