ljdm1956
    Wed Mar 19, 2014 6:29 pm
    East Durham, NY
Yup, same question multiple forums.
I either Tig, Mig, or Fluxcore, haven't stick welded in at least 30+yrs. Anyway, been messing with some 6011, noticed no real slag on the welds. Even opened up a fresh, sealed box cause the first few I tried were old, and laying on the bench in the open. Normal for 6011? Any thoughts? Thanks!
Lincoln Weld-Pak 180
Lincoln spool gun
Everlast PowerUltra 205p
AHP AlphaTig 200X
Assorted stuff
    Sun Oct 27, 2013 10:57 pm
Yep, 6011 and 6010 share that characteristic.
Scraping the weld with the chipping hammer is often all that is needed.
Wire wheel on angle grinder works good too.
I use a wire wheel or a brush. I’ll occasionally use a thin wheel if it’s on a pipe root and I think there might be a little stuck along the toes.
Mike Westbrook
    Wed Apr 04, 2018 8:13 pm
    Central pa
Cellulose coated basically covered in paper stiff stainless brush cleans the gray smokey powder off it's a good root rod for that reason gets in deep slag brushes off 011 ac/dc 010 dc both all positions works good on things found in the fence row or coated with 75 years of paint you can use it in a pinch to cut bevel and gouge by cranking the amperage though not pretty
Sent from my XT1254 using Tapatalk
