Function of Iron Oxide in MMA Flux?
Posted: Tue Aug 23, 2022 8:28 am
by Jack Ryan
What is the function of iron oxide in MMA flux?
AWS examples are 6019, 6020, 6027 and 7027 but I don't think I have come across them before.
ISO 2560 does not list iron oxide.
Jack
Re: Function of Iron Oxide in MMA Flux?
Posted: Wed Aug 24, 2022 9:25 am
by Gdarc21
The iron powder not only melts in the heat of the arc to increase deposition rate but also enables the electrode to carry a higher welding current than a 'standard' electrode. The iron powder is electrically conducting, so allowing some of the welding current to pass through the coating.
A quote from twi global
Posted: Wed Aug 24, 2022 9:27 am
by Gdarc21
Whats the interest for, if I may ask if not just curious. Are you planning a task where this is critical?
Posted: Wed Aug 24, 2022 7:41 pm
by Jack Ryan
Gdarc21 wrote: Wed Aug 24, 2022 9:25 am The iron powder not only melts in the heat of the arc to increase deposition rate but also enables the electrode to carry a higher welding current than a 'standard' electrode. The iron powder is electrically conducting, so allowing some of the welding current to pass through the coating.
Thanks, but that is iron powder, not iron oxide.
I have done more research and found some answers.
The question was asked regarding MMA but the same applies to flux core wire - both gas shielded and self-shielded.
Increasing Deposition Rate
The purpose of the iron is to increase the deposition rate (a function now served by iron powder) but the question remained, why iron oxide and not iron powder? As is often the case, there is not a single answer.
Additional Oxygen
Where argon rich shielding gases are used, the additional oxygen in iron oxide increases the reactive component of the shielding gas. The reactive gas increases penetration and the removal of impurities through oxidation.
tubular wires are optimised for particular ranges of shielding gas and those designed to use high argon mixtures may need iron oxide additions to the core to restore the desired oxygen balance.
Tubular Wire Welding by D. Widgery, p44
Hydrogen Control
Resistance to hydrogen (water) absorption.
The extruded electrodes with rutile, iron oxide and silicate coatings do not pick up so much moisture from the atmosphere and function quite well with a small absorbed content.
Improved penetration (depth of fusion) with the addition of reactive oxygen.
In manual metal-arc welding the flux coating to give deep penetration characteristics would contain
(a) iron oxide
(b) manganese
(c) cellulose
(d) calcium carbonate.
The Science and Practice of Welding Volume 2 10th Ed - The Practice of Welding, p12& p510
Iron Oxide as a Slag Producer
Similarly, if we use iron oxide (Fe2O3) and silicon dioxide (SiO2) in the covering of the electrode, in the heat of the arc they will combine chemically to form iron silicate, which floats to the top of the molten pool as a slag, protects the hot metal from further atmospheric oxidation and slows down the cooling rate of the weld.
iron oxide + silicon dioxide = iron silicate
Fe2O3 + 3SiO2 = Fe2(SiO3)3
The Science and Practice of Welding Volume 1 10th Ed - Welding Science and Technology, p58
There are other combinations as well such as Exx20 with a high iron oxide coating bonded with sodium silicate. It looks like iron oxide is firmly in the past now as ISO 2560 does not even list it as an option.
Thanks again,
Jack
Posted: Wed Aug 24, 2022 7:45 pm
by Jack Ryan
Gdarc21 wrote: Wed Aug 24, 2022 9:27 am Whats the interest for, if I may ask if not just curious. Are you planning a task where this is critical?
Just curious. Sorry, I can't help it. :)
Jack
Posted: Thu Aug 25, 2022 1:14 am
by tweake
thats interesting info. thx for posting that 8-)
Posted: Thu Aug 25, 2022 7:18 am
by Gdarc21
I have to ask, what do you think is the difference in the way they using the terms.
One is iron powder the other is iron and oxygen, which also occurs when burning iron powder.
I wonder if you didnt create question to just do an info dump. It is still widely used and to the best of my knowledge, Engineers are the very few people who care about ISO, Everyone else refers to AS/NZ STDS, WTIA notes and AWS in practise.
Posted: Thu Aug 25, 2022 7:35 am
by Jack Ryan
Gdarc21 wrote: Thu Aug 25, 2022 7:18 am I have to ask, what do you think is the difference in the way they using the terms.
Well, iron powder is just that, iron oxide is an oxide. Iron powder is used to increase the deposition rate, it is not burnt.
Who are you to make such accusations? If you are overwhelmed, move to the next post.
Widely used? Where?
A disappointing post I have to say.
Jack
Posted: Thu Aug 25, 2022 8:24 am
by Gdarc21
Jack Ryan wrote: Thu Aug 25, 2022 7:35 am
Widely used? Where?
Jack
Ah whatever :lol:
Posted: Fri Aug 26, 2022 12:18 am
by tweake
Gdarc21 wrote: Thu Aug 25, 2022 7:18 am It is still widely used and to the best of my knowledge,
i've never seen iron oxide rods. they certainly not widely used downunder.
in fact most listing of rod spec have no mention of iron oxide. i suspect its old tech thats been superseded a long time ago.
iron powder and iron oxide are two completely different things.
