pipelinedreams
- pipelinedreams
I have a Everlast 140st and im running 1/8 7018 between 95 amps to 110 and I welding vertical on 1/8 flat bar. and while Im doing my stingers what is a good amperage because I just keep burning holes in it. Because I have a welding competition at the end of January thanks!
1/8 flat bar---vertical up ? NOpipelinedreams wrote:I have a Everlast 140st and im running 1/8 7018 between 95 amps to 110 and I welding vertical on 1/8 flat bar. and while Im doing my stingers what is a good amperage because I just keep burning holes in it. Because I have a welding competition at the end of January thanks!
Go buy some 7014(or 6013) and downhand it.
What joint configuration?pipelinedreams wrote:I have a Everlast 140st and im running 1/8 7018 between 95 amps to 110 and I welding vertical on 1/8 flat bar. and while Im doing my stingers what is a good amperage because I just keep burning holes in it. Because I have a welding competition at the end of January thanks!
Tee? or Groove?
Details!!!!
pipelinedreams
- pipelinedreams
Ok so here is what I have to do .
1)3F uphill SMAW 7018 1/8 6 stringers Tee joint must be tacked 90 degrees
2) 3F uphill SMAW 7018 1/8 3 pass weave Tee joint must be tacked 90 degrees
3) 2F SMAW 7018 3/32 6 beads stringers
What a good amperage for these? I'm welding on 1/4 steel
1) Around 105amps. Give or take 10.pipelinedreams wrote:Ok so here is what I have to do .
2) Same as above.
3) Around 90amps. Take or give 10.
Dunk the plates in water between EACH pass. If possible.
Just my opinion.
But what would I know
- GreinTime
Apparently not much man, as I've seen you throw a disclaimer in like that the last few posts of yours I've seen. What gives? Normally you're so self-assured in your responses and advice.AKweldshop wrote: Just my opinion.
But what would I know![]()
GreinTime wrote:Apparently not much man, as I've seen you throw a disclaimer in like that the last few posts of yours I've seen. What gives? Normally you're so self-assured in your responses and advice.AKweldshop wrote: Just my opinion.
No two weldors weld alike.
My advice works for me, but doesn't always work for others....
JMO,
~John
Hey, Sam,GreinTime wrote:Apparently not much man, as I've seen you throw a disclaimer in like that the last few posts of yours I've seen. What gives? Normally you're so self-assured in your responses and advice.AKweldshop wrote: Just my opinion.
John's officially a grown-ass man.
He acknowledged the "your mileage may vary" factor in his reply.
Give credit where it's due.
- GreinTime
Yes, but your all of the sudden self-deprecating attitude is strange, and it almost sounds like you are fishing for validation from more knowledgeable members when offering advice to newer members. Just offer advice without the disclaimer at the end. You can say the same thing without just hanging it out there at the end, all alone like a bastion of uncertainty.
It's New Year's Eve, there are fireworks going off throughout my neighborhood, and I'm rather intoxicated.GreinTime wrote:Yes, but your all of the sudden self-deprecating attitude is strange, and it almost sounds like you are fishing for validation from more knowledgeable members when offering advice to newer members. Just offer advice without the disclaimer at the end. You can say the same thing without just hanging it out there at the end, all alone like a bastion of uncertainty.
I didn't mean to create drama.
It's five minutes to midnight, and my entire neighborhood sounds like a war zone from the fireworks.
Pretty cool.
Pretty cool.
