welding 1/8 in steel that has galvi. coating that I have sanded off. when I scratch rod it just sticks and won't start bead.
is my setting to low, too high? I'm using 6011, AC machine (duel range) It's an older machine that's been cleaned up.
any suggestions?
You didn't post the rod size and amps you've been trying.Welding2013 wrote:welding 1/8 in steel that has galvi. coating that I have sanded off. when I scratch rod it just sticks and won't start bead.
any suggestions?
What is your overall background in stick welding?
Welding2013
- Welding2013
3/32 rod, E6011, 75 amps low range. i used a grinder with sand paper disks, 80 grit. I will try cleaning up the ground/stinger contact areas.
