Hello fellow welders,
been lurking on here for a while, and finally have something of substance to post and hopefully get some feed back. as the subject line states, i'm in the market for a new welder.
currently I have a miller 180 auto set and the old Lincoln "tombstone" ac 225 in my shop. with these, i'm set up to weld most stuff out there, but there is an increasing need to weld thinner material. so I am looking into a tig welder that's geared toward a "hobbyist" like myself. I would really like to get a combo ac/dc stick and tig welder for the dc stick option especially. these welders usually have the "scratch and start tig" optional attachment I believe.
budget is always a consideration, but I am trying to keep this manageable around 5 bills.
if you experts out there have any suggestions, please respond.
thanks in advance fellas.
BFTrout
I'm a fan of big old monster welders - they are cheap and they flat out work.
$500 is too low to buy AC/DC tig welders unless you buy the big old beasties.
i had an old miller goldstar, big and bulky but it welded steel and aluminum
just fine. they can be had for $500 to $800.
soutthpaw
- soutthpaw
I've owned 3 of the Miller/Airco 330abp's. Great machines. Had to sell my last one when I sold my house and moved out of state. If I ever have a place to keep one again. I would definitely pick one upMinnesotaDave wrote:I'm a fan of big old monster welders - they are cheap and they flat out work.
Thanks for the replies fellas, and that in turn has sparked more questions.
I've been poking around the internet to find a machine that might suit my needs and have found specific information hard to come by. So I again propose the same question with a few refinements: is there a machine out there that will sick weld on ac and dc and also have the tig capability to weld stainless, mild steel and aluminum?
one machine in the price range that is close is the Hobart stickmate lx235ac/160dc, but only claims that it can tig weld stainless and mild steel with no mention of aluminum.
after my initial price range of 500$, it looks like I may have to double or triple that amount to potentially get exactly what I am looking for.
the other machine that caught my attention is the everlast 160 or 200, but believe this is only dc and will not tig aluminum.
my question seems better suited to an "equipment question" forum, but it appears none exists here.
thanks again for the comments and suggestions, please keep them coming.
BFT.
BFT.
soutthpaw
- soutthpaw
The stickmate does not have High Frequency. That's why you can't do aluminum. Plus trying to weld aluminum with a machine that does not have a pedal is a joke. If you want to PM me, I have a machine with warranty that might interest you. Will do everything you want @ your initial price range....
Everlast has several models with 200 in the name. Some are AC, some are not. The 185 power tig is also a good choice. But it's not that great of a stick welder. It, like many other inverters will not run E6010. Unless a machine specifically states it will run that, assume it won't. Though it's not a big deal unless you are doing code work that requires E6010.
After doing a little more internet searching this weekend, I came across another "potential" machine that would suit my needs.
My question is regarding the AHP AlphaTig ac/dc 200x. It appears that it has several of the high end features that expensive units have coming in around 8 bills. If I understand the specks correctly, this unit will do ac/dc stick and will allow the user to tig mild and stainless steel as well as aluminum. The unit comes with all the bells and whistles including a foot pedal.
Has anyone out there logged any time on this machine? If so, could you please comment on your likes and dislikes.
If there are other machines out there with the same features around the same price point, please pass those suggestions on as well.
Thanks again,
BFTrout.
Thanks again,
BFTrout.
plain ol Bill
- plain ol Bill
For your price range I agree w/ Craig. IF you can find a Miller Goldstar they are big but great machines,
Tired old welder
CNC plasma cutter
Colorful shop w/
CNC plasma cutter
Colorful shop w/
Sometimes you can pick up Miller Syncrowaves for fairly short money, maybe in the $1000 range for something big enough to do most practical stuff. I have a 180sd that I picked up for $900 with an 80 cf argon tank, cart, torch, regulator, stick lead and foot control. It was a low hour machine that looked brand new. I've tigged 1/2 steel and 3/8 aluminum with it. The aluminum was a bit slow going but it did get the job done.
I have other tig machines, bigger ones, but find myself using the 180 most of the time.
Search for the deals and don't be in a rush. Spring cleaning is coming and someone will be selling one.
I got a new everlast powertig 185 off eBay for 750 shipped. Haven't used it for aluminum yet but it definitely has the capability. Welds decently on stick mode but as mentioned it won't run 6010 for crap. 6011 is fine though.
soutthpaw
- soutthpaw
See my review i recently posted.BFTrout wrote:After doing a little more internet searching this weekend, I came across another "potential" machine that would suit my needs.
Thanks again,
BFTrout.
http://forum.weldingtipsandtricks.com/v ... php?t=7325
I also own the Everlast 185 it's also a good machine.
