hey guys just a quick question on 7018, what would make it spit and sputter and not catch a good arc?
dono if my rod got wet or what but even runnin flat that shit just keeps dropping fuckin dingleberries and not making a solid arc.
wasn't having this problem at all 2 weeks ago.
no rust or slag on the metal im welding.
heat is fine
it's also sticking like a son of a bitch.
i've used 7018 for years and never had problems like this so im getting really irritated.
it's ground through some grease but i wiggledit around and stuck it good and tight. was using 6010 and that was running like a dream so
i don't think it's the ground.
any thoughts would be great
Try putting several pieces in your oven for an hour at 350+ degrees. That should tell you if they got wet. Apparently, they can just absorb humidity.
You could also try buying a small amount of 7018 and see if the problem continues with the fresh rod.
anthonyfawley
- anthonyfawley
either wet rod or try grinding and cleaning a bit where your grounding. hope this helps.
Anthony
Anthony
99% they got damp or wet . Also and not being a smartass by anymeans but always have a CLEAN ground. 7018's are bad if theyve gotten wet...You want real bad try a 6011 thats absorbed moisture..Yeah might as well set off a roman candle lol
Let's hope it's wet flux.
I've actually welded with visibly wet 7018 and didn't have any real trouble. I suspect it's possible the machine has a bad diode. Take GWD's advice and dry some rod in the oven. If this doesn't solve the problem, suspect the machine. A bad diode wouldn't have a very noticable effect with 6010. I've even welded that rod on an AC machine like 6011, and it didn't perform poorly.
Good luck,
Steve
Good luck,
Steve
Greg From K/W
- Greg From K/W
harleyotto
- harleyotto
that answers my question too,i can't solve it
At the touch of love everyone becomes a poet.Blancpain Watches
What kind of machine are you runnin" ? One time I forgot to switch my leads on my Trailblazer from mig to stick and was stick welding on CV instead of CC and it was similar to what you described.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
m_a_r_c_u_s
- m_a_r_c_u_s
Check to make sure you aren't running on straight polarity DCEN instead of reverse DCEP, it will cause a sputtering in 7018 and will gouge. its an easy mistake and can happen when setting up in a hurry. just another thought.
