Stick_Welder_Steve
    Sun Nov 08, 2015 6:39 pm
I have been watching Jody's vids for about a year now and I remember he made a video titled "3 stick welders" where he presented 3 different stick welding machine. A Miller Thunderbolt, Lincoln AC buzzbox, and some kinda Everlast machine (forgot the name). Ever since that video I have been doing research on a various amount of machines...millers, lincolns, everlasts, esab, hobarts, etc. Ive been looking up duty cycles, amperage, input power, all of that good stuff and have gotten totally nothing on which one looks of utmost perfection and quality as far a what the specs tell me :x. First I go with the lincoln then with the hobart and then with the everlast. All recommendations are welcome (even multiprocess machines)
Merry Christmas!
    Wed Oct 23, 2013 3:30 pm
    Palmer AK
Merry Christmas to you.
What kind of welder are you looking for?
What stuff are you gonna weld?
Stick_Welder_Steve
AKweldshop wrote:Merry Christmas to you.
I will mostly use it to practice for my pipe and plate certs that I will take senior year. I also plan on building a couple of things such a smoker and anything else that happens to come across my mind . As far as the type of welder...I don't really mind as long as it will last for a reasonable amount of time and can produce quality arc, it also needs to have both AC and DC polarity in case I want to run some root passes with a 6010. For material thickness I would say about a max of 5/8 or 1/2.
    Palmer AK
Well for structeral and pipe with xx10 and xx18 I don't think you could beat a good lincoln invertec.
I've had two of the 275's, two of the 300pros, a 200 and a 250.
Smooth for 7018 and crisp for 6010.
You can find them around for $250-$1000.
Stick_Welder_Steve
Thank you! I will look into one as soon as possible :D. One more thing would you recommend buying one new or used?
I will second the recommendation of the Invertec 275. It's performance exceeds it's ratings.
The Miller XMT series is very similar in features and performance.
I'd price both, new and used, in your area, and talk to your local weld supply about whether red or blue has better/faster/closer service in your area should you have trouble. New with warranty, or used, fast reliable service adds value to whatever machine you choose.
I'll add that both machines have very good lift-arc TIG capabilities, and will run a suitcase MIG, so they're not just "one-trick ponies"
Stick_Welder_Steve
Otto Nobedder wrote:I will second the recommendation of the Invertec 275. It's performance exceeds it's ratings.
Do you know if they still sell the XMT on the Miller online store or would I have to look for a used unit?
    Palmer AK
Honestly I feel a used machine is a good value.
Your not gonna be using it for a business, just for practicing I take it.
New a Invertec is $2500.
Used is $500 to $1000.
A miller XMT 304 is $3500 new, but can be found for $1000-$1500 used.
If it welds good, buy it.
I've bought dozens upon dozens that way.
    Palmer AK
Don't buy from the miller online store.
Your LWS or some other online store like Cyberweld or others of the like. Much cheaper.
Yes you can buy them brand new, but they are everywhere used for a fraction of the cost.
If you like eBay I could find some links for ya.
Stick_Welder_Steve
AKweldshop wrote:Honestly I feel a used machine is a good value.
Infact I was just on the online website and saw an invertec 350 for 4,800k, so I will probably buy one used like you said. As for the XMT have you ever managed to get your hands on one and if so do you think it rivals the Invertec?
Last edited by Stick_Welder_Steve on Thu Dec 24, 2015 4:21 pm, edited 1 time in total.
BTW,
"You might be a welder if..."
You think red states and blue states refer to the popularity of Lincoln vs. Miller.... :roll:
Stick_Welder_Steve
Some links to get me started off would be great!
I (and I suspect John, also) have far more experience with the Invertec than the XMT, so it's hard for me to give a fair comparison.
    Palmer AK
Here's a decent xmt 304.
Lot's of deals on xmts and Invertecs show up on eBay weekly.
http://www.ebay.com/itm/MILLER-XMT-304- ... Sw1S9WeJ1m
Yeah I used to own a XMT 304. Bought it for $750 and sold it a week later for $2000
I just stick welded with it, and side by side I think the Lincoln welded better with both 6010 and 7018.
Stick_Welder_Steve
Many thanks to both of you for getting me hooked up and headed in the right direction! I will continue to look for used machines and if I happen to have anymore questions I will be sure let you guys know ;)
soutthpaw
    Thu Sep 18, 2014 12:14 pm
    Albuquerque NM
Wanting AC sick really limits your choice of inverter machines. If almost consider a used buzz box Lincoln for $50 or so then focus on a DC sick machine that will do 98% of your welds.
Many great options then. I have an older Thermal Arc LM300 it stick welds really nicely. Made in Japan with sanrex components, the older TA line are some of the best made inverters on the market. Powcon brand was the first American made inverters and also stick weld really nice. Many all on the used market.
If you are primarily looking to practice, don't stop a bunch of con now, wait till you finish schooling and r making money then get what you need for the job. The Everlast 140st is an amazing little machine that is affordable, 5 year warranty, dual voltage. And makes a great machine to toss in your vehicle and go anywhere. A great 2nd machine and also makes a good basic tig also. 15 more Amps on DC Than the Lincoln buzz box and infinite voltage adjustment not tapped as the Lincoln is. There is the 160 if you need a little more amps, which would let you run 5/32 7018.
The ESAB 161 is a great ask unit also.
I've seen a lot of good feedback from some very skilled welders on the larger everlast powerarc 200 and 300 if you want a more industrial machine.
Sent from mobile. Not responsible for Typos
    Sun Oct 27, 2013 10:57 pm
I like my Dialarc 250/250 if you don't need a light inverter - $250-400 will usually get you one used.
The lincoln idealarc is similar.
For inverters I have two lincoln invertecs, the v250s tig/stick and the 300 pro which also runs my wire feeder.
They both weld excellent and have high enough duty cycle for continuous heavy use like the Dialarc.
I had a miller maxstar 150s that I replaced with an ESAB 161.
Both weld fine, but are limited compared to the invertecs.
soutthpaw
    Albuquerque NM
Oh, I forgot to add that Arcon welders are the new Powcon welders. Definitely industrial duty machines.
    Wed Jan 22, 2014 12:00 am
    Connecticut
There have been a lot of old round top AC/DC Lincoln Idealarc 250's on Craigslist as of late, and they are pretty cheap...a couple of hundred bucks usually. You will not find a better stick welder for the money. Everyone you ask seems to love their arc quality. If stick is your thing, I am not sure how you pass one of these by.
Multimatic 255
Stick_Welder_Steve
Louie1961 wrote:There have been a lot of old round top AC/DC Lincoln Idealarc 250's on Craigslist as of late, and they are pretty cheap...a couple of hundred bucks usually. You will not find a better stick welder for the money. Everyone you ask seems to love their arc quality. If stick is your thing, I am not sure how you pass one of these by.
Wow you live in CT? Haha I live in East Hartford but I go to a manchester tech school for my trade (welding) ;)
    Connecticut
Heh, yeah. Too bad, you missed a couple of smoking deals recently.
I would offer this guy $500 for this machine. http://nwct.craigslist.org/tls/5340708732.html
This is the newer version of the same machine. Again I would try to talk him down http://boston.craigslist.org/gbs/hvo/5374513835.html
This one is a rebadged Miller. Not a bad machine if you can get it for a few bucks less. http://southcoast.craigslist.org/tls/5348509252.html
same for this one http://worcester.craigslist.org/tls/5356417854.html
Any of these would set you up quite well for stick welding practice, and there isn't much to break on these. They are bullet-proof transformers for the most part.
Multimatic 255
    Connecticut
This is an interesting welder if you have the means to move it and the space in the garage for it. TIG and Stick. Again, don't pay asking price. http://newhaven.craigslist.org/tls/5343007972.html
Always test the welder before handing over the cash. But you can get a very nice welder for not a lot of money if you look around Craigslist enough.
all of these welders are professional grade stuff, not really consumer grade, so they will do well for you in your practice. They are not under powered either. You would have to work pretty hard to hit the duty cycle limit on one of these
Multimatic 255
Nice welder choices Louie :)
    Connecticut
Trying to do a solid for a fellow nutmegger. Hate to see a young guy in school spend more than he needs to.
Multimatic 255
