Mike Westbrook
    Wed Apr 04, 2018 8:13 pm
    Central pa
I just inherited an l-tec 250 hf plus stick and Tig machine stick works fine tried the Tig side no hf opened it up and the logic board looks like it got shot with a tracer round I suspect the hf filter failed letting high voltage back to the board so who do you guys recommend to get a replacement for the logic board and the capacitor filter board did a quick search found a place in ky called York that list it will call them tomorrow thanks for thoughts and suggestions in advance ......board number 675421 and filter number 680042
Mike Westbrook
    Central pa
Tried York was a no go sort of at a loss on this old girl if nothing else it's a 200 lb ac dc stick welder called esab and it's obsolete [emoji848]
    Mon Feb 09, 2015 4:48 pm
    St. Johns, Michigan
Have you tried these guys? : https://www.innovatcorp.com/
Pete
Pete
Mike Westbrook
    Central pa
Have not I'll call them today thanks
    St. Johns, Michigan
This one as well: http://welderpartswarehouse.net/ I had a Syncrowave years ago that needed a main board, 800.00 dollars later after the repair I found a company that rebuild or repaired them for $250.00 its been so many years ago I can't remember exactly which one it was, but there are a few out there that do this type of work.
Pete
Mike Westbrook
    Central pa
I have called dozens problem is they only repair them I sort of need another one Image
    St. Johns, Michigan
Och, Just a long shot but did you contact ESAB?
Pete
Mike Westbrook
    Central pa
I called Esab and they said the famous last words no longer available and it's a shame because the machine is in great shape it stick welds beautifully and it came with all the hoses Regulators 60 foot cables two air-cooled torches and a pile of tungsten my buddy's work was going to toss it in the metal bin so I've got nothing invested in it just a shame somebody's got one somewhere
W8AT
    Fri Nov 02, 2018 7:23 pm
    Clarksburg, WV
Does the other side of the board have values of components silk screened on it or do you have a schematic of the circuit? You could rebuild that board and use jumpers where the traces are burnt off.
Mike Westbrook
    Central pa
It does and I do I thought about that except the hf vaporized the solder and it's burnt in everywhere so it will conduct
I've only been looking for a week hopefully in time I'll find a good repairable one I don't need the machine right away it just has way more amperage than the little Tig I have and I have a soft spot for old overweight tranny machines
    St. Johns, Michigan
Hopefully you can find a board for it, it would make for a very nice welder.
Pete
