Now that's an improvement!tweake wrote: had to repair this.
i bought a cheap freight damaged frame from a welding store and it looks like someone replaced a part.![]()
looks like flux core, no slag removed just painted over. didn't see any cleaned spot for earth clamp.
it also didn't fit well.
cut apart, tig back together. used old 2.4mm tig rod as packers to fill in a big gap.
quick grind and splash of paint.
- tungstendipper
Everlast 210 EXT
CJ737
Everlast 210 EXT
CJ737
This is what the potatoes look like up heretungstendipper wrote:I'll bet it was nice to weld something that didn't have to do with potatoes!JayWal wrote:A little Saturday afternoon project today, a carpenter buddy of mine wanted some carts made for his cabinetry shop. I thought this was a pretty simple design, it’s 30’ of 2x2 by 3/16 angle, 6’ and 5x1/4 flat bar for the casters to bolt to. Turned out all right I’d say. I told him I’d make one now in exchange for free range of his shop next Saturday and all the lumber I need for a new table and shelving in my storage room at work. And I’d make more in winter as I find time. He agreed :
He’ll just lay on a 3/4 sheet of plywood on top and cover it with carpet to avoid scratching his work pieces. Same with underneath. He’s happy, I’m happy
- 13D183D5-DB0B-4C99-9266-CCC99C41578C.jpeg (52.37 KiB) Viewed 6336 times
- tungstendipper
What's all that white stuff?
We are suppose to get that "stuff" here (eastern plains of Colorado) tonight.
Everlast 210 EXT
CJ737
Everlast 210 EXT
CJ737
The fellas wanted me to tack up some staino tube hanger brackets as they have difficulty buying them here in the backside of the world.
They picked up the 25x3 (1"x 1/8") flat and M10 nuts. They even cut it up, drilled them and marked the centres. All I had to do was sit at a nice clean bench on a stool with everything at my finger tips and tack em up. Didn't even get my hands dirty.
Incidentally, I used a third hand to hold down the opposite side of the first tack. Obviously it kept the nut in position while I tacked but what I also noticed that the nut stayed flat on the bar under the weight of the third hand. Without it the nut lifted slightly off the bar under shrinkage and therefore needed clamping.
This shop has a nice big band saw with repeat stop and pedestal drill, but the fellas marked out each piece then used battery grinder and drill. I had to sweep up after them. I said nothing.
- ss brackets.jpg (67.92 KiB) Viewed 6136 times
- F3F4BD7E-3349-41AE-994A-DC8F9D7AAC6F.jpeg (73.3 KiB) Viewed 6329 times
- Some of the stuff I’ve been working on lately
- ACEB352A-A51C-45C1-8A83-E3116C52ED71.jpeg (66.06 KiB) Viewed 6329 times
- 111EF07C-7265-44ED-8382-54E374867EB3.jpeg (49.93 KiB) Viewed 6328 times
- A77D2F98-2846-42DA-80FC-B0D4B9C17521.jpeg (57.31 KiB) Viewed 6328 times
Nice job Josh!
Staino is tidy and clean.
Ammonia pipes are, well, ammonia pipes but outside under that beautiful blue sky, I love that work. I notice the spaghetti is all done with socket weld, is that common practice over there?
Cheers,
Vic.
Cheers,
Vic.
Makes perfect sense to me I don’t know why we don’t do it here on ammonia work. Only time we see it is on assemblies out of the usa or on steam work. Getting harder to find the fittings too.
Sent using Tapatalk
Sent using Tapatalk
ROBERTINCREST
- ROBERTINCREST
Hello everybody,
Newbie here, Just starts learning TIG. Lots of great information on this forum, and videos. So I'd like to say thanks to all of you that contribute, and now its time for practice, practice, practice. here is some of mine.
- welding.jpg (128.28 KiB) Viewed 6210 times
Good solid start. Keep that tungsten sharp and the arc short. No more than the thickness of the electrode
- Aluminum skid plate for the BMW
- Finished and ready to the final buff.jpg (46.48 KiB) Viewed 6163 times
Plans for any drain holes? Or punched holes to strengthen it?bruce991 wrote:Finished and ready to the final buff.jpgI made this a few weeks ago out of aluminum 5056 3/16 thick and it has served me well to protect the underside of the adventure bike.
- tungstendipper
Those holes made it look like it was commercially made! Good job.
Everlast 210 EXT
CJ737
Everlast 210 EXT
CJ737
You did a nice job constructing that.bruce991 wrote:Added ventilation holes
I'm giggling a bit, exhaust systems don't need "ventilation" holes. In fact, the more protected they are from cooling air flow, the better they work. When you look at the manufactured systems of these skid plates, the holes are punched for strength, not ventilation. Because ally is pretty weak, having those punched holes increases it strength tremendously. And you do get some debris/moisture draining advantages, especially on an Adventure bike.
Exhausts that remain protected from cooling forces scavenge the exhaust gases better, and increase the gas flow rate. This is advantageous primarily along the header and until it passes the CAT, where most condensation starts, and rot attacks. Remember that hot air moves toward cold surfaces. So the gas internally is drawn to the perimeter of the pipe, then loses its energy (heat) as it is cooled, slowing down the flow and lessening the scavenging of the gases. You'll see folks wrap exhausts in pipe wrap which as an insulator is a good idea, except that this wrap (on bikes) is a terrible idea as the carbon steel pipes below rot prematurely due to moisture being trapped against the pipe. A ceramic coating inside is the best treatment, and outside for ambient temperature (your body's proximity) comfort. If the exhaust is stainless, the rot is less an issue, but the internal treatment still is a major advantage from effectiveness of scavenging.
(This was entirely for informational purposes, not criticism, so please accept it as such.)
not quite right.cj737 wrote:You did a nice job constructing that.bruce991 wrote:Added ventilation holes
I'm giggling a bit, exhaust systems don't need "ventilation" holes. In fact, the more protected they are from cooling air flow, the better they work. ............... You'll see folks wrap exhausts in pipe wrap which as an insulator is a good idea, except that this wrap (on bikes) is a terrible idea as the carbon steel pipes below rot prematurely due to moisture being trapped against the pipe. A ceramic coating inside is the best treatment, ........
its not rust that kills wrapped headers/pipes. its overheating the metal that does it. with the insulation on the outside the metal can't cool, it overheats and degrades.
however ceramic coating on the inside works great because the insulation is on the inside which keeps the pipes cool.
a bash plate doesn't need vent holes. theres tons of air flow around to keep the pipe cool. most cars have heat shields on exhaust parts (ie manifolds) and they generally have no vent holes.
not sure about cutting holes to add strength. you can get strength from holes if the edge is bent in. often use a die to press it in.
Hey Tweake, I didn't advise cutting holes I suggested punching holes as cut holes don't increase the strength where punching can. And we agree on the lack of venting, but I suggested drain holes in the bottom/punched holes serving the same purpose. An Adventure bike is prone to wet and dirty rides, and a flat tray beneath the motor is a strong candidate for collecting riding schmootz that needs to be evacuated.tweake wrote:cj737 wrote:a bash plate doesn't need vent holes. theres tons of air flow around to keep the pipe cool. most cars have heat shields on exhaust parts (ie manifolds) and they generally have no vent holes.bruce991 wrote:Added ventilation holes
Just in case we are unclear with each other-
Getting back on the picture train.
Dave H Ti by Mike Zanconato, on Flickr
