Hey guys I am starting to get into trying to tig weld again..... the biggest thing that has me discouraged is every time i add filler it turns the puddle gray I can just have the arc going on the stainless and be shinny but when I add the filler rod it turn it to a gray color.
I started out 10 ga at 115 A worked my way all the way down to 50 amps I am using 1/16 tungsten 2% Thoriated with a # 8 cup to try to keep the filler in the 100% argon after being dipped, after I trimmed the end and tried lay wire. Nothing it gets hard when the welds look bad in color to get focused on the shape.... any advice?
Jason_alex
- Jason_alex
Jason_alex
- Jason_alex
2nd picture
Middle one was only a arch the other 2 where with filler added.
304SS Plate with 308 Filler
- 20141018_140519.jpg (37.79 KiB) Viewed 2488 times
- Braehill
Jason,
There's a point while welding stainless that the base metal reaches a temp (885*F if memory serves me) that promotes oxidation. You're probably going through that temp range right after you add filler metal, hence the color change, the gray is oxidation. If it cleans up with a brush, then it's fine. You can avoid this by keeping the puddle in the gas longer (i.e. bigger cup/more gas) so the puddle is enveloped in it while it goes through that temp range.
Jason_alex
- Jason_alex
Jason_alex
- Jason_alex
I'm new here and a little rusty with stainless, but I'm sure I haven't ever used a #8 cup doing stainless. I like a #5 or #6. Keeps the gas tight. Looks to me like you've got a gas issue. A lot depends to the machine you are using and your settings. Trying to guess at the exact issue without knowing the settings leave a wider area or guessing without any way of really knowing.
THANKS Jack
THANKS Jack
One thing you might try is actually turning your amps up! Basically get in, and get out as fast as possible. Jody did a video about it before showing that trying to weld too cold puts more heat into the material than welding hot with a quick travel speed.
Jason,
My opinion, in the first picture you can see a hint of "color" but the welds look a little lumpy. I believe you are to low of amperage and are sitting there to long allowing the heat to build up. Evidence of that is actually the weld profile, not enough amps to completely lay the bead flat but to much dwell time causing heat input. The second thing I see actually points to to much heat but on the opposite end of the spectrum. The bottom bead is to hot. See how the bead is black and extremely flat? Again, either to much amperage or the plate was already to hot and running the given amperage to much heat input was put in causing it to "sugar".
To sum it up, it will take seat time to get thinner gauge SS down. It is not the easiest in my opinion. Keep up the good work and get us some updated pictures!
christhewelder75
- christhewelder75
I'm certainly no expert on tig or stainless (am wrapping up 8 weeks of schooling for my second year this week 3weeksGTAW 5 of SMAW) but i am thinking u are getting too much heat into the material.
one of our test welds is a 3F on i think 14ga stainless. i run my machine (dynasty 200) at 43amp with pulse 4.6pps 80% and 40%
and once getting the puddle goin i try to move thru as quick as possible while still getting fusion on the toes.
stainless seems picky, like if i bump the pulse per second up to 5 and i get bad color and issues.
Christhewelder75,
You're not going to like this, but...
If, in an eight-week course, you're learning all about pulse, you're not learning to weld. You're learning to use advanced features to make beads.
The pulse features should not be introduced until you've been welding at least a year with some measurable success.
You'll be sorely disappointed when you take that weld test for the job you want, and they hand you an old Synchrowave or PrecisionTig transformer machine, and you have to do it (what, to you will appear to be) the hard way.
I am somewhat old fashioned
With or without school one should still find a mentor to become a welder
The right mentor will accelerate the learning curve no matter what the chosen profession.
The ability to listen/observe/evaluate valued added
Two kinds of good welders, Skill gifted,Skill aquired A good welder is not just a machine operator
Like OTTO says be prepared to test
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
kiwi2wheels
- kiwi2wheels
Being a grumpy old barsteward , it always surprised me that people would try to TIG ( or buy a welder ! ) without ever reading about the principles and techniques. To say nothing of the " nuts and bolts " of the hardware , consumables, etc.
If you have an idea what you are trying to do, it makes it somewhat easier to identify and correct problems when you are starting out. From then on , you never stop learning............................Agree 100% with rick9345.
I quite like this publication ; http://www.amazon.co.uk/Gas-Tungsten-Ar ... b_title_bk
Maybe Jody could add it to his store offerings.
christhewelder75
- christhewelder75
for the record this is a course for apprentices with 3000+ hours to move from second to third year apprenticesOtto Nobedder wrote:Christhewelder75,
I wouldnt say the course was "all about pulse" it was presented as a way to help control heat input into our stainless steel welds on thin materials.
it was presented as a tool to help with aluminum welds to help with using the dip technique. (didnt much like it for alum.)
We were taught first on how to work without pulse and get used to that before being introduced to the pulse options and advantages.
I definately need a ton more helmet time with tig to say i'm "proficient" in all aspects but it never hurts knowing how to use tech to your advantage when its available. At the same time i totally get what you're saying one needs a base of knowledge on how to do things with the bare minimum as well as with all the bells and whistles.
either way not much i can do about second year technical training curriculum
i have had lots of fun playing around with their gear:)
3F stainless
2G GTAW root on 3/8" mild steel plate
A good welder is their own worst critique
Everlast 250EX
My apologies, Chris,
I saw "8-week course", with no reference to it being a "stage" in a longer program. An 8-week course on its's own is what I was dogging on. Since this is an 8-week "stage" in a much longer course, please disregard my previous comments.
christhewelder75
- christhewelder75
no worries at all steve
the system for training here in canada is a bit different from that in the US from what i understand
so so true.Postby rick9345 » Thu Oct 23, 2014 6:42 am
