StephenPerkins
- StephenPerkins
Can someone mock up a wps for me or even give me something that you've taken a test on. I want it to be all tig 5g or 6g. If I sound like an idiot you can call me one idc thanks stephen
If I remember, I'll make a .jpg photo of the WPS for the ASME IX test I took. I'll also take .jpgs of the WPS posted on my "calibrated" TIG welder for ASME "R" work. (Unless they're the same... I don't recall.)
I am working tomorrow, so may be able to share it tomorrow evening.
The test WPS was surprisingly generic, with a very broad range of acceptable parameters, but code approved.
StephenPerkins
- StephenPerkins
Crap, I forgot today!
I'm working tomorrow, too, and I'll write myself a note right now!
[EDIT] Written, and in the top of my lunch bucket.
If Steve forgets again I have copies of mine I can share although I will have to edit a few things.
StephenPerkins
- StephenPerkins
Awright, I remembered today. These shots are in VGA size, so if you can't make them out (at my screen size I can read them, but "just"), let me know and I'll take some hi-res , put 'em on DropBox, and post the links here.
- GEDC1644.JPG (166.35 KiB) Viewed 1375 times
- GEDC1645.JPG (168.83 KiB) Viewed 1375 times
StephenPerkins
- StephenPerkins
You're welcome.
This is the actual WPS I took my ASME IX cert under.
Interestingly, they did a four-bend, instead of an x-ray. I'd have preferred the x-ray, but "whatever"... A "pass" is a "pass".
