Ah, the old Shop Gremlins curse I see... this explains many of your issuesBillE.Dee wrote:Who the hell changes the environment when I'm not looking anyway ???
One thing you may be overlooking, is that once you get your weld going, the material is becoming heat soaked and easier to weld the next bead. If you take a substantial break, the material has cooled, and you need to “start again” to get the material up to temperature. Of course, not allowing the material to cool while welding is also a curse, because it becomes too hot and the weld will crawl away from you.
It’s all just learning curves...
