i would get the torch angle a lot more vertical ie 10 degrees.Tweepy wrote:Thanks tweake & VA-Sawyer
- the cleaning (DC offset) can be set from 0 to 50% on this machine, I tried from 25 to 35%
- changed the electrode for a 2.4mm @ 140A, with a #10 collet, tip does ball, but not much
- the coupon are scrap from the shop down the street, brand new, they solder it daily, but no idea what is it.
- filler is 2mm AlMg5, that's what the same shop recommended
- torch angle regular 45/50°
The puddle is shiny in few second, but there is always a black smear on the middle, not going on the sides, even without filler.
but other than that i would suspect the aluminium. maybe thats why they solder it instead of weld it.
