Steve49suzuki
- Steve49suzuki
I have a question on this. I can weld aluminium with a gas lense and do ok. Now a lot of the great aluminium welders use standard ceramic lenses. Now I can't weld at all with a standard lense I have practice loads gas pressure stick out or flat to lense, frequency balance tried everything. Now I can get buy just fine but would love to master standard set up ? Any advice ? It general looks like a gas coverage problem does anyone know of any tricks like a modified collet body or use a diffuser? I'm at a loss. Cheers
Bill Beauregard
- Bill Beauregard
For me they work about equally well. I use more stick out with lens. I understand you use less CFH with lens.
Steve49suzuki
- Steve49suzuki
Bill Beauregard
- Bill Beauregard
Something else is at play here, I have an aerator on my kitchen faucet, it pours smoother with less splash. I don't have one it comes out too fast, splashes a bit. Some people have them, some don't. Something doesn't fit right, you have leaks, your nozzle is plugged, I don't know yet. The difference should be noticeable, but not extreme. Tell us about all your settings. I'd guess you need slightly more flow rate without a lens.
kiwi2wheels
- kiwi2wheels
There was a post recently on an earlier thread about the collet restricting flow.Steve49suzuki wrote:I just can't seem to get it to work for me. No problems with a gas lenses.
Do you know the brand of the standard collet body that 's giving you the problem ? Have you tried another from a " name " supplier ; e.g. Weldcraft, C&K, Speedway et al. ?
Steve49suzuki
- Steve49suzuki
Hello that's great I will look it up. It's just a standard cheap one that comes with my welder. I will look into buying a branded one and try that. Cheerskiwi2wheels wrote:There was a post recently on an earlier thread about the collet restricting flow.Steve49suzuki wrote:I just can't seem to get it to work for me. No problems with a gas lenses.
kiwi2wheels
- kiwi2wheels
I was a bit unclear. I should have you'll need both collet and collet body.Steve49suzuki wrote:Hello that's great I will look it up. It's just a standard cheap one that comes with my welder. I will look into buying a branded one and try that. Cheerskiwi2wheels wrote:There was a post recently on an earlier thread about the collet restricting flow.Steve49suzuki wrote:I just can't seem to get it to work for me. No problems with a gas lenses.
In relation to stigmas, I want to ask about repairing alum bicycle frames. There seems to be a school of thought that if a Tig welded one cracks, it can be rewelded due to work hardening. Could this be true in all cases or only some. My idea is if it's cracked already, might as well have a go at fixing it.
This fellow offers some 'Tips and Tricks' https://www.youtube.com/watch?v=6emWh53WpZI
weldin mike 27 wrote:In relation to stigmas, I want to ask about repairing alum bicycle frames. There seems to be a school of thought that if a Tig welded one cracks, it can be rewelded due to work hardening. Could this be true in all cases or only some. My idea is if it's cracked already, might as well have a go at fixing it.
Bill Beauregard
- Bill Beauregard
I wonder if a crack can develop without some crystallization nearby. I'd want to cut away a fairly wide gap, maybe 1/2" wide, then build it up. Then move around to the other side and repeat the process.
Repairing cracks is something I do quite often.
The key is knowing the actual end of the crack. I do this with dye-penetrant.
On thin materials I will stop-drill just outside the ends.
On thicker sections, I'll grind the whole thing out and replace everything with fresh filler.
Cracks always extend beyond what the naked eye can see, and will come back of not allowed for.
Bill Beauregard
- Bill Beauregard
I want to think of the cause of the crack, and how I can change the situation to prevent it happening again. Reinforcement is an obvious solution, but often that isn't the best solution. Often it's vibration, and it can be addressed. Bad designs can be changed, or an extra fastener might eliminate the problem.
