Page 125 of 131
Posted: Thu Aug 13, 2020 1:15 pm
by TraditionalToolworks
LtBadd wrote:Thanks for the comments, the table was given to me by a customer, I just had to get it moved
Now I'm getting green along with VA-Sawyer...those are good customers to have!
And not that you don't deserve it Richard, it's good to see someone use and take care of something like that, the way it should be! That's a win-win, IMO.
![Cool 8-)](./images/smilies/icon_cool.gif)
Posted: Thu Aug 13, 2020 3:35 pm
by sbaker56
You sure can tig weld a hell of a lot better than I ever have
Posted: Thu Aug 13, 2020 4:44 pm
sbaker56 wrote:You sure can tig weld a hell of a lot better than I ever have
Thanks, most of my (later)welding career has been TIG, just worked out that way with the shops I've been worked for.
This would have been a good candidate for MIG if I had one.
Posted: Thu Aug 13, 2020 8:33 pm
by Spartan
LtBadd wrote:sbaker56 wrote:You sure can tig weld a hell of a lot better than I ever have
Yeah, but we all know that MIG sucks
Posted: Wed Aug 19, 2020 1:13 am
by tweake
![image005.jpg](./download/file.php?id=17077&sid=7426a996058d93e8317488f7f53ff400)
- image005.jpg (110.03 KiB) Viewed 3866 times
when you need an arm rest.
Posted: Wed Aug 19, 2020 8:51 pm
by sbaker56
Just some tig practice, I welded a couple pieces of an old grader blade together just because I wanted to see how realistically cracking would be an issue, and although it welds like crap for some reason I suddenly hit my groove for half the pass and made it look okay anyway.
![20200819_150550.jpg](./download/file.php?id=17078&sid=7426a996058d93e8317488f7f53ff400)
- 20200819_150550.jpg (79.62 KiB) Viewed 3822 times
Posted: Mon Aug 24, 2020 10:46 pm
by Spartan
Fixture mounts. Customer initially intended to mostly have these pressed into shape, but they had some problems with that, so asked me if I could cut them up and weld the pieces together. I obliged. Couple dozen more to do. Kind of nice since they are laser cut parts, but also kind of a pain with some of those awkward angles.
![IMG_2489(1).jpg](./download/file.php?id=17091&sid=7426a996058d93e8317488f7f53ff400)
- IMG_2489(1).jpg (48.04 KiB) Viewed 3778 times
![IMG_2496(1).jpg](./download/file.php?id=17092&sid=7426a996058d93e8317488f7f53ff400)
- IMG_2496(1).jpg (47.41 KiB) Viewed 3778 times
Posted: Tue Aug 25, 2020 6:33 am
Nice!
Posted: Tue Aug 25, 2020 6:55 am
by BillE.Dee
VERY Nice !!
Posted: Tue Aug 25, 2020 7:09 am
by Coldman
Very nice. Did you cut them up or nick them half way through and fold down into position?
Posted: Tue Aug 25, 2020 8:56 am
by Spartan
Coldman wrote:Very nice. Did you cut them up or nick them half way through and fold down into position?
Just cut them all the way through on the bandsaw. Seemed like the easiest route.
Posted: Sat Aug 29, 2020 4:22 pm
Made a stand for my metal blade chop saw, using scrap 1¼ " square tube and scrap ½ " OSB.
Small cutting "station" away from my welders and other machines
![Image](https://drive.google.com/uc?export=view&id=1q7NSS5Tm1LwjY2MEvARL8P5fePS8JNnX)
Posted: Sat Aug 29, 2020 6:08 pm
Looks good Oscar
Posted: Sat Aug 29, 2020 6:31 pm
Oscar wrote:Made a stand for my metal blade chop saw, using scrap 1¼ " square tube and scrap ½ " OSB.
For all the money you’ve spent on those super duper MIG machines, you need to dial up the heat. The interior welds on your legs are stone cold.
Posted: Sat Aug 29, 2020 6:38 pm
Yea it's not bad for scrap. I go almost every weekend to see what I can get from a local metal supply. $0.32/lb just because it has a 6" long unwelded seam, or slight curve, or a slight 2° twist to it. Perfectly usable in my eyes.
All that tubing including the 6" pipe I bought as scrap.
cj737 wrote:For all the money you’ve spent on those super duper MIG machines, you need to dial up the heat. The interior welds on your legs are stone cold.
I kept them cold on purpose so things don't shift on me.
The chop saw will not make that table collapse, so it's all good.
Posted: Sat Aug 29, 2020 8:43 pm
by Spartan
Very Nice! I love making useful things out of scrap...especially when it's scrap from stock that somebody else paid for
Posted: Sat Aug 29, 2020 8:45 pm
by DavidR8
Oscar wrote:Yea it's not bad for scrap. I go almost every weekend to see what I can get from a local metal supply. $0.32/lb just because it has a 6" long unwelded seam, or slight curve, or a slight 2° twist to it. Perfectly usable in my eyes.
I’m completely envious of your scrap finds. There is no such thing as scrap steel where I live.
Posted: Sat Aug 29, 2020 8:52 pm
DavidR8 wrote:I’m completely envious of your scrap finds. There is no such thing as scrap steel where I live.
Texas is a big place. There's room for ya over here. Come on down!
Posted: Mon Aug 31, 2020 9:45 am
by croshaul
Speaking of chop saws. I have a Craftsman 10" that I would like to put a metal cutting blade on. It's probably 15 yrs old but still works well but it's been set aside for my Dewalt 12" compound miter saw. Do you think the old Craftsman is up to the task? I would like to give purpose.
Posted: Mon Aug 31, 2020 12:18 pm
croshaul wrote:Speaking of chop saws. I have a Craftsman 10" that I would like to put a metal cutting blade on. It's probably 15 yrs old but still works well but it's been set aside for my Dewalt 12" compound miter saw. Do you think the old Craftsman is up to the task? I would like to give purpose.
Careful on the speed, you'll chew through carbide blades unless it's slow RPM (i.e., 1600 or less).
Posted: Mon Aug 31, 2020 8:35 pm
If it is a wood saw, forget about it. There are specialty blades I've seen (carbide tipped blades that is), that actually can withstand the RPMs of a wood chop/miter saw, but they cost....let's say.......more than some welding machines.
Posted: Mon Aug 31, 2020 11:54 pm
by BugHunter
I can get my hands on small amounts of scrap from time to time but nothing like that. Wow. I did get a bunch of four, five, six and eight inch pipe in schedule 40 for free recently. I didn't have room to take all of it nor did I have need.
Posted: Tue Sep 01, 2020 8:16 am
Oscar wrote:cj737 wrote:For all the money you’ve spent on those super duper MIG machines, you need to dial up the heat. The interior welds on your legs are stone cold.
Sure you did. No welder ever intentionally lays cold beads on a finished product. They would either properly tack it, or weld it properly.
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
Posted: Tue Sep 01, 2020 1:48 pm
by BugHunter
Had to weld a bunch of extrusions again today.
Posted: Wed Sep 02, 2020 4:26 pm
by BillE.Dee
Nice, Buggy. Are you back to building and trying to wear out that hammer ... AGAIN?
