[emoji106]Thatkid2diesel wrote:I'll add a couple things.
First one is the connection point on an old farm boom sprayer. It was a 11:00pm quick job had to have it by morning on our family farm. Metal was very thin. Took my time to try to fill some other bug holes some of which kept blowing out, but I got them filled. Not very pretty but lasted to get the job done, and should last for a long time.
Second project I went ahead and did the same night. It is the shifter handle on a family friends John Deere Gator XUV 550. He has the clutch problems where it's very hard to shift. The last incident when trying to shift broke the shifter handle right off. Since then, the clutch has been fixed by the JD clutch doc and no more issues. I ended up tacking it in 2 spots, then took my carbide burr and ground down to center, then welded, continued to grind all the way down to the center all the way around to try to get a full weld. I used 1/16th filler rod so there wasn't much grinding needed to allow it to fit back in the shifter housing. Solid as a rock. I added pics of the carbide burr set I used. Inexpensive off Amazon and fit my Dremel. They worked great for this piece.
Sent from my Pixel 6 Pro using Tapatalk
