    Mon May 11, 2015 9:00 pm
    TN, USA
A four port manifold with QD fittings. These fittings have internal shutoff valves. I used 1/8 ID silicon tubing (400° rated). You will still have to use 1/8 OD metal tubes if you need to purge close to your weld. McM-Carr has the fittings.
Thermal Arc Ultraflex 350 Pulse
Thermal Arc Feeder HMC-410
Thermal Arc ArcMaster 400MSTP
