has anyone found a source for 1 or 2 lb. containers of the new 4943 filler ?
(or also the 4047 either)
It would corrode before I used 10 lbs. ......
Thanks,
Tim
If there is an aluminium Boat Propeller repair shop in your area,check with them,as they usually use 4047&4943 to build up dirty,corroded damaged props.
10# mins is a lot for a small shop.
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
- ldbtx
Here's 4047...
https://www.weldingsuppliesfromioc.com/ ... 4047-tn-bp
They also have 1/16" and 1/8".
Miller Bobcat 225
Tweco Fabricator 211i
AHP AlphaTIG 200x
Lincoln SP-135+
Hypertherm Powermax 30 Air
ProStar O/A torch
AHP AlphaTIG 200x
Lincoln SP-135+
ProStar O/A torch
