New to Tig welding, what do i need to get started
Posted: Sun Mar 19, 2017 2:35 pm
by flytyer232
Hello,
I am new to this forum, but have been welding for a couple of years, as i have passed the 3/4g welding tests (back when i welded for a living, with mig/stick). Currently i just weld for hobby, and side cash, welding mostly Mig and Stick, though i just picked up n AHP AlhpaTig. I decided on this machine, as it would be a good starter machine on a tight budget.
My question is, what else do i need to begin learning how to tig weld? i already have plenty of scrap 1/8-1/2 inch thick mild steel, and aluminum plate around.
Here is a list that i have put together so far, please let me know what you think:
Filler Rod:
-5lb ER70s-6 1/16"x36"
-5lb ER70s-6 1/8"x36"
-5lb ER309L 1/16"x36"
-5lb ER4043 1/16"x36"
-5lb ER4043 3/32"x36"
Tungstens:
-20x 2% Lanthanated (Blue), 3/32" (2.4mm)
-5x 2% Lanthanated (Blue), 1/8" (3.2mm)
-5x 2% Lanthanated (Blue), 0.40" (1mm)
As far as torch components, i have no idea what to get, or if i need to get anything. Please let me know if there is anything else i need, to get started. My plan is to practice with steel 1st, then move to aluminium, will probably take a couple of months. I already have several good auto darkening elements, welding gloves, tig finger, etc.....
For my argon tank i have a mid sized one, i think around 140 CuFt, hopefully that is good enough.
I am trying to do things on a budget, as i am a full time college student (Electrical Engineering), so i don't have much disposable funds...
Thanks,
Mike
Re: New to Tig welding, what do i need to get started
Posted: Sun Mar 19, 2017 3:06 pm
by Farmwelding
Well that is a pretty good start! Eventually you'll need more filler, especially when you start aluminum. Other than that you've got everything to start. No need for a special torch set up just yet. Make it work with what comes for know.
Posted: Sun Mar 19, 2017 5:42 pm
by WoodpeckerWelder
Farmwelding wrote:Well that is a pretty good start! Eventually you'll need more filler, especially when you start aluminum. Other than that you've got everything to start. No need for a special torch set up just yet. Make it work with what comes for know.
+1 There is a guy at work that for the most part uses the same setup for everything he welds. The only thing that he changes is the type of tungsten and the polarity. Generally it is : 1/8" tungsten, #8 cup, thumbwheel on his torch, and the machine maxed out @ 310 amps. If he is doing something very precise, he may change the size of his tungsten. (He also TIGs without gloves and has been in the trade for 33 years.....)
Posted: Sun Mar 19, 2017 5:50 pm
by Farmwelding
WoodpeckerWelder wrote:Farmwelding wrote:Well that is a pretty good start! Eventually you'll need more filler, especially when you start aluminum. Other than that you've got everything to start. No need for a special torch set up just yet. Make it work with what comes for know.
I'll bet his hands are tougher than the steel he welds
I guess I won't knock the method if it works.
Posted: Sun Mar 19, 2017 6:11 pm
Our 250DXs max out a 310 Amps, and I will set them there when using the thumbwheel (so all the current I need is in one swipe of my thumb). We jokingly refer to it as "taking the 3:10 to Yuma".
Posted: Sun Mar 19, 2017 6:12 pm
We also commonly set the machine at 222 Amps, because it's 1/3 evil...
Posted: Sun Mar 19, 2017 6:14 pm
by flytyer232
Hum.... I don't know that i would weld without gloves, as i have gotten bad burns with gloves (dual shield flux core....). How do the UV light affects your hands?
So i shouldn't worry about getting a gas lens kit (whatever that is, though i hear Jody marketing them all the time)?
thanks,
Mike
Posted: Sun Mar 19, 2017 6:18 pm
flytyer232 wrote:Hum.... I don't know that i would weld without gloves, as i have gotten bad burns with gloves (dual shield flux core....). How do the UV light affects your hands?
thanks,
Mike
Gas Lens is a good thing, but not required to start. Work with what you have, and upgrade as you can.
To weld without gloves/sleeves, use sunblock. I use SPF45 all the time (Apply twice a day to arms, more often for hands because you wear it off) because it's too damn hot to weld in sleeves on the gulf coast in the summertime.
Posted: Sun Mar 19, 2017 6:19 pm
by WoodpeckerWelder
Otto Nobedder wrote:We also commonly set the machine at 222 Amps, because it's 1/3 evil...
Yep. Same machine. Same rationale.
Posted: Sun Mar 19, 2017 6:20 pm
by Farmwelding
thanks,
Mike
I'd wait awhile to invest in something like a gas lens kit or a stubby kit or something. To learn you just want bare bones. So don't use all of the extra dials on your machine for awhile either. Just amperage and polarity and maybe pre/post flow to save on gas a little maybe.
Oh and I think I'll just go with a jacket and gloves. Or nothing if I'm on the farm. All you need is the hood there. Too hot in the shop and no other gear to use anyways. That's the farmer way-cheap and any damage to my body ain't that bad.
Posted: Sun Mar 19, 2017 6:25 pm
by flytyer232
Well up here, in the north it is currently warm out (25 degrees F), and generally the only source of heat in the shop is the welder... So, i always wear gloves....
What exactly does a gaslens do, that the regular setup doesn't?
Posted: Sun Mar 19, 2017 6:28 pm
by flytyer232
Okay, i guess i will hold off on that for now, though i did order some spare parts for the torch (collets, and cups), as i will probably break a few.....
Posted: Sun Mar 19, 2017 6:33 pm
by Farmwelding
flytyer232 wrote:Okay, i guess i will hold off on that for now, though i did order some spare parts for the torch (collets, and cups), as i will probably break a few.....
Don't drop the torch and you shouldn't have to worry about them breaking. I guess you may need some other collets for the different size tungstens.
Posted: Sun Mar 19, 2017 6:38 pm
by flytyer232
Oh, i will try not to do that.... So you need different size collects for different size tungsten?
Posted: Sun Mar 19, 2017 6:44 pm
by Farmwelding
flytyer232 wrote:Oh, i will try not to do that.... So you need different size collects for different size tungsten?
Yes sir. Can't got an 1/8" in a 3/32" and sure as hell can't get a current out of a .040" tigster with a 3/32" collet. And a gas lens helps shield the arc and your tungsten better. Look up some pictures and look do the ones that show gas coming out of the torch.
Posted: Sun Mar 19, 2017 6:52 pm
by flytyer232
Okay, will get some of those. Should 5 collets, and 2 collet bodies (in each size) be okay for a couple of months? The reason i ask, is the like to place large orders, as it is hard to find that stuff in town.....
Posted: Sun Mar 19, 2017 7:02 pm
Grab yourself one of Jodys Stubby Gas lens TIG kits. It comes with cups and gas lenses, collects and tungstens in each size to get you going. Plus, spending upon the bundle, you get a TIG finger that is useful when you get cranking on heavy material.
Posted: Mon Mar 20, 2017 6:29 am
by Keith_J
thanks,
Mike
The UV burns the epidermis making a stench that doesn't wash off. And the arc burns are deep. I only go bare for tacks under 50 amps. I weld thin stuff mostly but still glove and cover for most. Shade #9 is my standard but have gone as low as 7
..only for 28 gauge stainless.
