recently started tig welding about a month ago. been having problems with my tungstens becoming contaminated every time i lay a bead down. sounds and looks i am mig welding. using a lincoln precision 225 machine with straight argon.
mostly been welding chrome moly and mild steel. pretty sure my metal prep is in par, as i used a flapper wheel, scotch brite. i wipe metal, tungsten, and filler rod with acetone prior to welding. tried different tungstens, different argon flow, ground positions.not sure what i am doing wrong here. it seems to me that it appears to be some form of contamination.
one thing i have noticed is my arcs just do not look right.
thanks
themadreefer
- themadreefer
rickbreezy
- rickbreezy
Using it for grinding tungsten only. If used for grinding other materials, the other material will embed itself into the grinding stone, and then embed itself into the tungsten from the stone the next time you grind tungsten.rickbreezy wrote:What makes a grinder "dedicated"?
Millermatic 251
Spectrum 300 Plasma
Everlast PowerTig 250EX
Everlast PowerCool W300
Harris/Victor OA
Craftsman 13 Speed Drill Press
ProTools Air/Hydraulic Bender
48" Brake
Compressor, Notchers, Grinders, etc.
Spectrum 300 Plasma
Harris/Victor OA
48" Brake
kermdawg
- kermdawg
Is it kinda sputtering or spitting with alot of black soot? If its somethin like that then you either have to low gas flow or bad gas.
jason.hwnd
- jason.hwnd
themadreefer
- themadreefer
no black soot. thought an indication of lack of gas, was inside of nozzle turning yellow, which i experienced earlier along.
one thing i do notice, every time i tack weld, i have a ring of what appears to be rust color around every tack.
jason.hwnd
- jason.hwnd
