I decided to start practicing with 1/8" aluminum because it's easier to prepare than steel. It made a big difference and allowed me to spend a lot more time welding. Now I have questions.
1. Sometimes the arc just will not start. If I move the torch from a place where it won't start, I can find a place where it will start. What's up with that?
2. I was trying to do lap welds, and the arc absolutely refuses to stay put. I want it down in the joint, but it bounces between the flat piece and the upper corner of the upper piece. How do I make it stay in the joint? I was chasing the puddle all over the place.
I found some suggested settings, and that's what I used. I was at around 140 amps (with the pedal) and 25% AC balance. I started at 75 Hz, but I read somewhere that increasing the frequency would make it easier to aim the arc, so I tried again at 125, and things seemed better (but still bad). I used a 3/32" E3 tungsten.
The first time I welded, I used aluminum pieces that had been wiped down but not cleaned in any other way. The second time, I polished them with sandpaper and followed with acetone. Didn't seem to matter.
Welding flat beads on top of the pieces seemed about like welding steel, except that I had to move fast to keep the metal from melting too much.
- Chips O'Toole
- Farmwelding
If your arc is wandering it may be the tungsten sharpening. As for the arc not starting, I have that happen all the time while I practice and usually i end up scratching it like a scratch start rig which isn't a good idea idea due to arc strikes. It may be due to poor ground, or maybe try cleaning the aluminum more with a stainless wire brush and acetone. Sometimes it helps.
Mash that pedal. Don't be shy and sneak up on it. The arc will only focus when you put power behind it. It will still want to wander from one piece to the other, but if you hit it fast and hard, you won't wonder where it's going. Manipulate the torch back and forth across this phenomenon until you see molten metal tight in the corner, and add your first bit of rod.
Once you add rod and tie the two sides together, everything gets easier, as the arc will find the puddle, not the sides. This is where what I said about advancing to the front of the puddle and waiting for it to follow you before adding more rod comes in to play.
- Chips O'Toole
Should I be welding with a balled up tungsten? Some Youtube dude says he fries his tungstens with DC to ball them up before doing aluminum. I was just putting about a 3/16"-long point on it with the belt grinder.
Your tungsten will ball all by itself. Only in critical code welds do I ball it first, and then I just use normal settings on some scrap. If you have scrap at hand, that whole "DCEP to ball" thing is wasted time. I grind a short taper, and blunt the point, and call it good.
- Farmwelding
See I don't get this. I've welded a decent chunk of aluminum for the years I've been on this earth( all 17) and I've only used 3/32" ceriated because that's what my school has. I've run from 60-180 amps and never once had it balled. Hell it barely loses its point at 180 amps. The only time my tungsten changes is when I dip-which I don't do as much now. Although the guy Im teaching had a ball on the end of his tungsten the other day that a pen cap couldn't go over. Stabbed it constantly with stainless rod and couldn't figure why his plate wasn't melting and his arc was wandering.Otto Nobedder wrote:Your tungsten will ball all by itself. Only in critical code welds do I ball it first, and then I just use normal settings on some scrap. If you have scrap at hand, that whole "DCEP to ball" thing is wasted time. I grind a short taper, and blunt the point, and call it good.
- Chips O'Toole
Just listen to Steve (Otto), don't argue with him.Farmwelding wrote:See I don't get this. I've welded a decent chunk of aluminum for the years I've been on this earth( all 17) and I've only used 3/32" ceriated because that's what my school has. I've run from 60-180 amps and never once had it balled. Hell it barely loses its point at 180 amps. The only time my tungsten changes is when I dip-which I don't do as much now. Although the guy Im teaching had a ball on the end of his tungsten the other day that a pen cap couldn't go over. Stabbed it constantly with stainless rod and couldn't figure why his plate wasn't melting and his arc was wandering.Otto Nobedder wrote:Your tungsten will ball all by itself. Only in critical code welds do I ball it first, and then I just use normal settings on some scrap. If you have scrap at hand, that whole "DCEP to ball" thing is wasted time. I grind a short taper, and blunt the point, and call it good.
Your machine is running enough negative balance that it doesn't ball - and 180 amps is very small besides.
On a 50/50 machine like my Airco, 1/8" pure balls up right away and welds very well like that.
1/8" thoriated takes longer to ball, but won't always ball smooth.
For the OP, more amps (170-180), full pedal immediately, the arc will straighten out - reduce after you start welding as needed.
There's this one Youtube channel that gives really good advice with regards to anything and everything regarding this thread. Look for a channel called weldingtipsandtricks, and some dude that makes those videos gives pretty darn good advice.Chips O'Toole wrote:Should I be welding with a balled up tungsten? Some Youtube dude says he fries his tungstens with DC to ball them up before doing aluminum. I was just putting about a 3/16"-long point on it with the belt grinder.
LOL!!Oscar wrote:There's this one Youtube channel that gives really good advice with regards to anything and everything regarding this thread. Look for a channel called weldingtipsandtricks, and some dude that makes those videos gives pretty darn good advice.Chips O'Toole wrote:Should I be welding with a balled up tungsten? Some Youtube dude says he fries his tungstens with DC to ball them up before doing aluminum. I was just putting about a 3/16"-long point on it with the belt grinder.![]()
I've heard of the guy too
- Farmwelding
Yeah I've kind of figured that out. When Steve says something just go with it. He's got my respect from all the crao he's done. Many others here too but...MinnesotaDave wrote:Just listen to Steve (Otto), don't argue with him.Farmwelding wrote:See I don't get this. I've welded a decent chunk of aluminum for the years I've been on this earth( all 17) and I've only used 3/32" ceriated because that's what my school has. I've run from 60-180 amps and never once had it balled. Hell it barely loses its point at 180 amps. The only time my tungsten changes is when I dip-which I don't do as much now. Although the guy Im teaching had a ball on the end of his tungsten the other day that a pen cap couldn't go over. Stabbed it constantly with stainless rod and couldn't figure why his plate wasn't melting and his arc was wandering.Otto Nobedder wrote:Your tungsten will ball all by itself. Only in critical code welds do I ball it first, and then I just use normal settings on some scrap. If you have scrap at hand, that whole "DCEP to ball" thing is wasted time. I grind a short taper, and blunt the point, and call it good.
Although I thought 180 amps was real heavy on AC current for 3/32"
180 IS heavy amps for a 3/32 tungsten, but I usually try for clean enough to set the balance at 10 (max penetration), which allows a lot of amps. I have 1/8 pure tungsten, but didn't switch to it for my recent project welding about 1/4" (Actually, schedule 40 and some 1/4" plate. If you see the ball quiver, you're too hot for the tungsten size and it could puke into your weld.
One of these days, I'll get to use a high quality inverter machine again, and will be able to use the Lanthanated tungsten everyone raves about.
Not for the ceriated tungsten you're using with the diversion tig.Farmwelding wrote: Although I thought 180 amps was real heavy on AC current for 3/32"
Since it runs better balance than the 50/50 of old machines, you're on a different part of the chart.
- image.jpeg (49.17 KiB) Viewed 1077 times
Good info, Dave, thanks for the chart. It seems to show the limit for 3/32 pure at 160A at 70% EN, but I think "10" on my synchrowave is 80% EN which is why I was able to stay within the limits and not dig out my 1/8" stuff. I was set at 225A, but only used that to initiate the puddle, backing off as the heat built up. Of course, those pictures are on another thread...
80% is pretty darn good - my old Syncro 350 that I picked up only goes to 68%
I wonder what the upper limit is for "just enough" cleaning?
- Chips O'Toole
I am working to apply the advice I'm getting. The welds are still hideous, but now they ARE welds.
My rod-feeding is pretty lame, and it seems to cause more problems with aluminum, because if you screw up, the weld goes nuts while you're trying to get your left hand straightened out.
I decided to order some lanthanated tungstens, because my belief is that skill is no substitute for buying new tools.
Make a flat pad of beads, half overlap every prior bead so the top ends up flat.Chips O'Toole wrote:I am working to apply the advice I'm getting. The welds are still hideous, but now they ARE welds.
Use 1/8" thick and at least 8" x 8" so it's big enough to not overheat on every bead.
Once you finish a few of those, your feeding hand should be much better.
Skill and practice wins over buying tools any day
After about 100 hours it all gets easier.
- Farmwelding
Yep... Pad beads all day long and you will start to worry about the puddle rather than feeding wire. And as Johnny Cash once sang-Get rythm. Find that pulse that gets you going. Try music or a metronome. It helped me when I was starting. Balance the puddle and dipping rod win the pulse of some good ole country.MinnesotaDave wrote:Make a flat pad of beads, half overlap every prior bead so the top ends up flat.Chips O'Toole wrote:I am working to apply the advice I'm getting. The welds are still hideous, but now they ARE welds.
Y'know what's crazy? I can weld well with either hand, but I only recently realized that when the torch is in my left hand, I can't feed rod worth a damn with my right. That's messed up!
Steve
Steve
- Chips O'Toole
I decided to see if lanthanated tungsten was any more friendly than E3. I have a feeling the problem will still boil down to a total lack of skill on my part.
When I started playing guitar, I thought better guitars would make me play better. Seat time is the only way...lot's of it tooChips O'Toole wrote:I decided to see if lanthanated tungsten was any more friendly than E3. I have a feeling the problem will still boil down to a total lack of skill on my part.
You're actually changing the least significant thing when switching those two tungstens.Chips O'Toole wrote:I decided to see if lanthanated tungsten was any more friendly than E3. I have a feeling the problem will still boil down to a total lack of skill on my part.
In my opinion.
- Chips O'Toole
Best I can do. If I changed the part that's causing most of the problems, someone else would be using my welder.MinnesotaDave wrote:You're actually changing the least significant thing when switching those two tungstens.
In my opinion.
Now that's funny.Chips O'Toole wrote: If I changed the part that's causing most of the problems, someone else would be using my welder.
I had been using zirconiated tungsten on a transformer machine and really liked it, switched to an inverter machine and it arced over to the gas lens and everywhere but the aluminum- basically unuseable. Went to a 2% lanthanated and had good luck, also ceriated worked well. I had a bit less luck with E3, it seemed to always run hotter for me and create a wider, dull colored bead, but it was acceptable. I think professional welders can use any tungsten and make it work. For home hobbyists and amateurs, I think trying different things can tip the balance in our favor.
Lincoln Square Wave 200
Lincoln 225 AC/DC
Harris Oxy/Acetylene torch
Lincoln 225 AC/DC
Ah, the loose nut behind the wrench is more of an issueChips O'Toole wrote:Best I can do. If I changed the part that's causing most of the problems, someone else would be using my welder.MinnesotaDave wrote:You're actually changing the least significant thing when switching those two tungstens.
In my opinion.
