Page 1 of 2
Gearing up - Way too many questions
Posted: Thu Mar 01, 2018 4:35 am
by Datsun510
So my 2018 AHP 200x finally arrived and I'm in need of supplies for hobby projects in both steel and aluminum.
I'll be running the machine on 110V for the time being. I'm a new welder with zero time on TIG, and very very minimal MIG experience. I have more questions than answers at this point, so please give some advice where you can.
I'm already over my budget so I need to be frugal about the following choices, but I'd rather spend smart money up front to avoid hassles later.
Gas
I need to pick up a 100% Argon bottle for TIG. I've read about the dangers of buying Craigslist "customer owned" bottles and think I have the lay of the land http://www.ebay.com/gds/BUYING-A-GAS-OR ... 737/g.html. The local AirGas supplier says they refill customer bottles, or swap out with smooth-necked bottles.
Welding at 10-20 CFH with an 80 CF bottle only gets you 4-8 hours of weld time before refill. That doesn't seem like much time.
The local welding supply isn't open on weekends, so refilling during the week will be a PITA.
I'm thinking of going with an S sized bottle, but I haven't seen any of these in person quite yet. I've got a Prius (yeah, yeah, I know, don't hate me) so transporting is a concern. That said, I did stuff a 5.7L Buick short block in the back at one point to go to a machine shop. The irony of that moment was not lost on me :D
That's a long way to say, do you think an S or K sized bottle is too large for a casual hobbyist?
Tungsten
Based on the majority of advice and videos I've watched I'm going to start with 2% Lanthanated tungsten (1/16 & 3/32)
On Amazon they have some deals from Midwest Tungsten Service, and are about 1/2 the price of the CK version sold on this site. Are they half the quality?
I want to support this site with buying things from the store but since I'll only be laying practice beads and dipping tungsten in the puddle for a while, should I wait to buy the CK stuff? Or will I be creating bad habits by using cheap materials?
Filler Rod
Same question as above. Amazon sells Blue Demon ER70S-2 (for mild steel, right?), what should I be using for general aluminum?
Harbor freight sells ER70S-2, ER4043 and ER5356
Stubby Gas Lens
There isn't a single video that doesn't, at some point, talk about the advantages of a gas lens. Ok, so I'll get one, but I'm confused.
If I have a 17 torch, i'd get this kit?
https://weldmongerstore.com/collections ... s-lens-kit
If I want to go Furick. I'll need this, right?
https://weldmongerstore.com/products/fu ... 26-torches
And once I have that adapter I can put on any sized Furick cup ? It's been recommend I start with a #8 cup?
How does this stuff compare to the CK Gas Saver series? Those lenses don't seem to be "stubby".
The Furick lenses need 20-30CFM? What do the CK Gas Saver Series need? Worth it?
Aside from possibly breaking a Pyrex cup, how long do they last? Do I need 4 of them, as in the Pro Cup 4-pack bundle? Are they considered a consumable, or do they need regular cleaning? (I know the mesh screens may get plugged up after a while, but what about the glass? Will it break over time?)
Collets
Wedge Collets seem to get great feedback from a lot of people, but will they work with a stubby gas lens?
I found the CK 3C332GS Collet Wedge for 3/32" 2.4 mm 3 Series Gas Saver. Wondering if these will these work if I get a Furick stubby gas lens?
Chop Saw
I've got a 3 1/2 HP Harbor Freight chop saw with abrasive disk that I absolutely hate. It spits dust and crap everywhere and the cuts are often ragged or heat discolored. Anyone ever buy a metallic blade for this? Better results?
Portaband vs horizontal band saw vs upright band saw vs grinder with cut-off wheel
As an alternative to the chop saw, I've seen a lot of videos using the vertically mounted Portaband, and checked out the Swag Off Road table that fits various portaband brands.
Should I go this route or just buy a regular vertical bandsaw off or CL? Between the Swag table and a used portaband (or HF version) I'm looking at $275? The Central Machinery Horizontal Band Saw is about the same price, but is it awful?
The short of it is, I need to cut steel and aluminum, what do I need to do it?
Fume Extraction/ Protection
For this I've got an open door and standard box fan. If I open my garage door I'll get a stiff breeze that will likely blow away most shielding gas. What should I be using to protect myself? I found this, but am curious as to what you guys are using, if anything: https://www.pksafety.com/blog/how-can-y ... ing-fumes/
Haha, this! https://www.millerwelds.com/safety/resp ... i-r-264575
That's it?
Ridiculous, right? Sorry for the massive list. Just wait until I start welding, I might just need to call you directly :oops:
Re: Gearing up - Way too many questions
Posted: Thu Mar 01, 2018 5:06 am
by tweake
i'm a beginner but my 2cents worth.
keep in mind welding is only 10% of the job. your going to spend a lot of time setting up, cleaning, prepping and then 30 sec welding. 8 hours actual welding can be a lot.
i would not worry to much about gas lens just yet.
standard gear will do fine. jody has some great footage of some excellent welding done with just standard gear.
tho i can understand wanting to save gas with a gas lens.
furick/clear cups, same thing. tho someone mentioned you need a very good helmet to work with them as the extra light plays tricks with cheap sensors.
they are handy but not needed.
wedge collets are great but split collets work just fine to.
chop saw, you can't use metal blades with them as the rpm is wrong.
a band saw would be good. but if just starting an angle grinder with cut of wheels and good old fashion hacksaw.
fumes, garage door and a cheap fan.
i'm not sure about the tungsten or alloy filler rod. tho i did just get er4043.
i try to go for filler rod that works with as much stuff as possible.
gas, no idea. depends on whats available locally. over this side of the world i went with hire bottles. buy your own are expensive and can be rejected for refill for stupid reasons.
i hope that helps.
Posted: Thu Mar 01, 2018 8:27 am
I differ in some areas than Tweake...
GAS - lease a bottle from your LWS. Its much, much easier. An 80 tank is small and it tends to run low at the worst possible moments. Either you're too low on a Friday to finish your work through Monday, OR, you exchange and refill it and are wasting 1/4 of your gas. Leased bottles can be refilled by any location of that store nationwide.
TUNGSTEN - Get 3/32 and 1/8. Ditch the 1/16. 2% Lanthanated with an inverter will serve you perfectly.
FILLER ROD - ER70S2 in 1/16, 3/32 and 1/8 and you can weld the world. Brand doesn't matter too much really, I get 10# boxes of Crown Alloy through IOC delivered cost effectively.
For aluminum, I use only 4943 and 5356 in 3/32 and 1/8. I stopped using 4043 after experimenting with 4943.
STUBBY GAS LENS - If you opt for Furick cups, you want Miller brand gas lenses. They have a dedicated O-ring slot, are larger surface area, and hold his Pyrex cups much better. And you DO want to use a gas lens from the get-go. Cups I use 5, 8 and 12s. I switched over to his ceramic cups recently and am getting better mileage out of them as I tend to break things when they hit the shop floor :oops:
For his 8 cup, you'll run ~15CFH, up to 25CFH with a 12. Argon is your friend when welding, use it lovingly. Your welds like it, your tungsten appreciates it, and the LWS is delighted when you refill it. ;)
SAWS - Tough question, but if I had to chose a single saw it would be flip bandsaw with a quality blade. Aluminum you can cut with a Compound miter saw with a rough tooth easily, but steel wants lots of fine teeth, a carbide blade, and slow speed to protect your blade. A grinder is a must anyway, so grab a decent stock of slicer wheels and flap disks. You can make lots of quick cuts and fast work of your cutting with a quality Metabo angle grinder.
FUME EXTRACTION - Use good, common sense. If you're welding in your garage shop, install an attic fan in the gable end. Unless yours is fully insulated, there's ample inbound air penetrating to help cycle the air-air exchange with a mechanical exhaust fan. You should NEVER weld on galvanized indoors or out, so mild steel, aluminum, and stainless don't really produce enough toxins that simple common sense and some air circulation won't provide adequate safety. (Provided you aren't welding in a broom closet :o ;) )
VOLTAGE - If you plan to weld aluminum on TIG, you'd best upgrade your service to 220v. you can get away with 110 on DC for thin stuff, but your machine will have no duty cycle, insufficient heat range and not get you where you need to go with 110v service.
Sorry for the lengthy post.
Posted: Thu Mar 01, 2018 8:29 am
by jwmelvin
You sound like me from a few months ago.
I rented a 330 cf tank; local suppliers don’t deal with any customer tanks larger than 80 cf and that seemed annoying. And larger tanks are a lot less for the gas itself.
I bought a gas-lens kit on Amazon for my -20 torch (smaller so no stubby required). It seems to work fine. While I have noted the wedge collet, I haven’t bought any yet. I’ve been using the Midwest Tungsten 3/32”, 2% lanthated and it seems fine so far.
I bought a variety of filler but probably shouldn’t have gotten 3/32” ER70-S6 as it seems 1/16” is more appropriate for most of what I do. For aluminum, 3/32” filler is good (for 1/8” work) and I have both 4043 and 5356. It sounds like 4934 is much better than 4043 but I didn’t know that at the time. I also got some of the 308L stainless rod to experiment with and 309L for mixed steel. And Si-bronze and Al-bronze. Bakers Gas Supply was good for filler; check them and Amazon.
I recently bought the 4x6 HF bandsaw and it seems good though haven’t yet adjusted it to cut straight and changed the blade. I do have the new blade (from McMaster) and will adjust the rollers when I put that on.
You will need angle grinders. I have three and it’s barely enough (cutoff wheel, grinding wheel, sanding disc); could use one with a wire cup too. I just got a small angle for grinder to help too.
So far fumes haven’t been a huge issue. I wear a half-face 3M cartridge respirator with P95 dust filters and that helps considerably. On the recommendation of someone here or on WW I bought a Striker Supreme XL helmet and it is fantastic.
You will want some TIG gloves. I’m experimenting with a few of the Tillman options.
Posted: Thu Mar 01, 2018 9:30 am
by tungstendipper
Get as many cutting devices as you can (as time goes by, you will). It's nice to have options.
Posted: Sat Mar 03, 2018 1:30 am
by ex framie
Datto 1600,
I ended up buying my bottles.
But we seem to have a different system here in oz.
I have 2 D sized bottles, when empty I call the supplier I bought them from and they deliver a serviceable full one. You just pay for the gas, a price that in the usa would make your eyes bleed.
Bottles here have a 10 year life before inspection.
Also they run about 500 psi less than the monthly rental one from boc, liquid aire and core gas.
Still im about 300 a year in front over renral of 2 bottles.
The rest you seem to gave a handle on.
Cheers
Posted: Mon Mar 05, 2018 12:20 am
by Datsun510
tweake wrote:i'm a beginner but my 2cents worth.
i hope that helps.
Yep, that al makes sense! thanks taking the time to respond. I'll post an update in a moment
Posted: Mon Mar 05, 2018 1:02 am
by Datsun510
cj737 wrote:I differ in some areas than Tweake...
Thanks for the reply!
GAS - I ended up buying a full 100% Argon/ 154 CUFT customer owed bottle from a guy off of Craigslist for $150. He's an older gentleman who runs a muffler shop, and it's his side business to sell bottles. He threw a gauge on it to show it had 2,100psi, which he said was an indication that it was "full". Then he spent a long time giving me advise about bottles, refills, and welding in general. He said if any places give me trouble he'll have his guy swap it out. So that's a nice worse case scenario. I had called three of my LWS's and they all said they'd do refills on customer bottles this size. This particular bottle is about to expire (thus the price) and will need to be hydro-tested, which is fine. The LWS all say it'll be $30 to have that done.
TUNGSTEN and Filler Rod - The only LWS open this Saturday had really limited selection of materials, so I had to get 3/32 2% Thoriated tungsten (got 3 of them), and 1/8" 4043 (only bought 1#)
STUBBY GAS LENS - I may delay this purchase for a bit as funds are low, but i'll keep you thoughts in mind, thanks!
SAWS - You say "...would be flip bandsaw" Is that a typo, or a type of bandsaw?
I've got a 4 1/2" Makita angle grinder, but sounds like another 1 or 2 HF versions would be handy to avoid changing discs.
FUME EXTRACTION - I did some welding today which I'll post about in a minute) and cracked the garage door and set up a fan to pull the fumes away from me. Seemed to do a decent job, but I think I'll go with a welding-grade respirator as well. I don't have a gable fan, and will likely install one at some point.
VOLTAGE - I was on 110v today and surprised I was getting the penetration/ heat that I got. But this was just bead on plate. 3-4" beads weren't a problem at 135 amps, we'll see how it goes as I'm able to weld longer (and straighter) beads.
Thanks again for the thoughts.
-Cory
Posted: Mon Mar 05, 2018 1:22 am
by Datsun510
jwmelvin wrote:You sound like me from a few months ago.
Noted on the Midwest Tungsten, I'll probably experiment with a few brands, CK being one of them.
Keep me posted on you HF bandsaw adventure, I'd be interested if you can tune it in properly.
I used my HF welding helmet today and it seemed to work just fine, or at least I'm not blind yet. I'll pitch it an first sign of failure.
I'm also using some leather HF welding gloves which seemed to work ok, a bit bulky but ok for now, I'll check out the Tillman stuff.
Thanks!
Posted: Mon Mar 05, 2018 1:23 am
by Datsun510
tungstendipper wrote:Get as many cutting devices as you can (as time goes by, you will). It's nice to have options.
I do enjoy a good hobby that requires me to buy tools ;-)
Posted: Mon Mar 05, 2018 1:29 am
by Datsun510
ex framie wrote:Datto 1600,
Cheers
haha, yes the ole' Datto 1600. Here she is:
sleeper engine.jpg (76.82 KiB) Viewed 6156 times
I ended up with an customer owned "S" sized bottle, inspection is 10 years here as well.
Thanks for the input!
Posted: Mon Mar 05, 2018 2:18 am
by tweake
Datsun510 wrote: SAWS - You say "...would be flip bandsaw" Is that a typo, or a type of bandsaw?
-Cory
i think hes referring to a horizontal bandsaw that can flip up and become a vertical bandsaw.
Posted: Mon Mar 05, 2018 8:11 am
by tungstendipper
What a sweet car!! How quick is it? Horsepower? Weight?
Posted: Mon Mar 05, 2018 2:01 pm
by Franz©
OK, you got a machine, and you got a cylinder of gas, and it sounds like the man who sold you the cylinder was fairly honest since he gave you a pressure gauge and explained how to use it to you.
Now, lets look at what you haven't got!
It definitely sounds like you haven't got experience welding with a gas torch, so you're going to read a truckload of crap on the InTURDnet, and believe too much of it.
Then again, what do I know, I only been at this trade since before Heliarc came along in every shop.
FIRST, build yourself a decent VENTILATION system, NOT an Exhaust System, before you grab your first Argon headache or puke in your helmet. You don't need either experience. Ventilation means replacement air for the contaminated air the fan sucks out. DO IT RIGHT!
Then grab a hunk of Tungsten, and some steel and spend a few hours learning what you can do with the arc. Don't even think about sticking 2 pieces together, just learn how to walk the arc around and control puddles. Don't get all wrapped up in which Tungsten BigmouthBob on the Welderbaiter board said to use, we did it all with 1 grade of Tungsten for 20 years before all the experts came along and we did it pretty well too.
Don't even try adding filler to the puddle till you can steer the arc where it needs to go.
Once you have the arc down, start trying to add filler and grinding tungsten.
Once you got the grinding and filler down, clamp a couple pieces up and see if you can stick them together without adding filler. When you have that conquered, run down to the toy store and get yourself some playdough and some popsicle sticks. That will allow you to learn weld building cheap and without a helmet. It's also a hell of a lot cheaper.
When you get it firmly understood the popsicle stick is your torch arc, put the helmet on and duplicate what you did with the playdough with the torch.
Now practice till you can do it laying flat on the bench with repeat-ability. Don't even think about vertical till you have horizontal down. Also don't try aluminum till you have steel conquered.
You should have thrown the shopping list out someplace along the time line.
Posted: Mon Mar 05, 2018 7:37 pm
Franz© wrote:OK, you got a machine, and you got a cylinder of gas, and it sounds like the man who sold you the cylinder was fairly honest since he gave you a pressure gauge and explained how to use it to you.
Heavy is the crown... :roll:
Posted: Tue Mar 06, 2018 8:19 pm
by Datsun510
-Cory
Ah, thanks Tweake.
Posted: Tue Mar 06, 2018 8:56 pm
by Datsun510
tungstendipper wrote:What a sweet car!! How quick is it? Horsepower? Weight?
Thanks! My dad bought it back in '69, was my first car in high school, been wrenching on it for 30+ years now.
It's got a bone stock exterior/ interior, the rest is all Datsun race car. A really clean sleeper.
It's not the fastest but it moves pretty well. 0-60 was around 5.4 sec with the last motor (roughly 165 HP). That cam was pretty mild. It's 2.0L punched out to 2.2L with fuel injection, 42mm throttle bodies (peak TQ was around 5,200 rpm), 4:11 rear with Subaru LSD, adjustable coilovers at all 4 corners, camber plates, 5-speed, comp header and exhaust, etc etc. Weighs in at 2,150 lbs with full 10 gal tank of gas. Despite the weight, it handles like a slot car. Incredibly fun to drive though the canyons or on the track.
I just built a new motor with a higher flowing cylinder heads and much more aggressive cam. I'm likely getting 44mm throttle bodies, and in the process of installing a Motec M130 and PDM15 (the first Electromotive Tec II EFI system finally died on me), along with Injector Dynamics fuel injectors, CV rear axel kit. I should get much better numbers out of this new combo.
2nd stage plans will be to strap on a Lysholm twin screw supercharger and get 350 rear-wheel HP out of it. I've got 2nd engine that is already build for boost (o-ring block, forged pistons/ rods, ARP fasteners, etc). The Motec M130 has an amazing traction control feature, so it'll be 350 usable HP starting around 2,100 rpm, which will be bananas. I'll probably lose the 4:11 rear (maybe drop down to 3.60) and get a much bigger carrier/ LSD to handle the torque.
To bring this all back around to welding... my goal is to fabricate the brackets that the SC will be mounted to. Even if I just learn to tack it together, I'll save in the design costs and learn a hobby at the same time.
Posted: Tue Mar 06, 2018 9:09 pm
by Datsun510
Well, it looks like I took half of your advice on my own, but there's always room for improvement: http://forum.weldingtipsandtricks.com/v ... =5&t=13070
You should ignore my attempts at aluminum to keep your blood pressure down ;-)
Some of the other guys suggest I start with stick, and I'll see if I can safely give that a go. I only have 110V and need an extension cord that can reach out to a well ventilated place. Speaking of ventilation, I'm right there with you. I value my lungs. andI need to get a respirator, gable fan, etc. My garage has a pretty decent cross flow if I tune both end doors just right.
I think I hear what your saying though: You gotta go slow to go fast.
I'll keep that in mind as I practice.
Thanks for taking the time to reply.
Posted: Tue Mar 06, 2018 10:17 pm
by Franz©
I got a whole bottle full of pills for the blood pressure so no need for concern on that score.
Maybe this approach will work for you.
Ya learn to drive the B-210 before you even think about the Z car.
Melting metal together so it turns back solid someplace other than on the floor is an ancient black art, and electric melters didn't come along till the last century.
When you have a rod in one hand and a torch in the other and you're trying to see through a wall and make it happen, there is just too much going on for a kid with no experience to get through. If you mastered O/A from behind a shade 5 lens you have a good start on mastering Heliarc. That process has only been around since the 60s.
It's not all that hard if you go about it 1 metal at a time, and understand you'll drop a lot of puddles on the floor. Might even be easier than welding aluminum with Oxy/Hydrogen.
Take a break between steel and aluminum and learn about oxidation rates and spend some time learning the difference between a solvent and a cleaner.
Posted: Wed Mar 07, 2018 12:18 am
by Datsun510
Franz© wrote:I got a whole bottle full of pills for the blood pressure so no need for concern on that score.
I was just busting your chops. I hear you, Franz.
As the old saying goes, "There are many roads to Rome". I'll pick one, for three, and enjoy the inevitable lessons of humility on the way.
I recently bought the book called Metals And How to Weld Them, so I figure that's a good start at understanding the basics.
I don't have the money, nor the space, to buy an O/A setup, so I'll have to just figure out Heliarc the hard way, one error at a time. Luckily my living isn't based on welding, so I've got time to make puddles on the floor.
Posted: Wed Mar 07, 2018 12:58 am
TIG welding can be done by mere mortals with some guidance, lots of practice, and more guidance along the way. Given your confession about your objectives and background, I think you'll be rather capable of getting 2 pieces of metal to stick together without risking someone's life needlessly.
Your 110v welder will be your limitation, not your ambition or devotion or interest. Whenever you can, wire up a 220v outlet near a workbench and close to the garage door (so you can work outside when appropriate) and then invest in a welder more suited to your interest level and needs. A 110v TIG will do "auto" and restoration type work on steel all day long. It won't be a production level machine, and it will miss some fancy features, but with some patience and technique, it will do the job.
I dig the 510. Lots!
Edit: I just realized from your other thread you have an AHP. Very capable machine, so ignore that bit above. But it sounds like you might need the power receptacle perhaps? To do ally TIG, you will want 220v.
Posted: Wed Mar 07, 2018 3:08 am
by Franz©
I don't have the money, nor the space, to buy an O/A setup, so I'll have to just figure out Heliarc the hard way, one error at a time. Luckily my living isn't based on welding, so I've got time to make puddles on the floor.[/quote]
You put me in mind of a young buck back in the 60s, got on a brewery job where an old pipe weldor was nailing together 2-4" stainless beer pipes and some black iron pipe too. That old man was a real golden arm, and the young buck figured he'd get some learning. Young buck had his own Lincoln buzzbox at home, and on the way out one night the old golden arm handed the young buck a fist full of SS rod telling him to go burn and learn. Few days later they're having lunch and the old boy asks the young buck how he's doing with the SS. Young buck sits there and hangs his head admitting he can't keep that damn rod burning to save his ass.
Golden arm pulls a paperback rod book out of his pocket and tosses it to the young buck. Young buck thumbs through and when he gets to the right page he sees the rod is DC only. That afternoon the young buck gave that same rod a try on the SA 200 and learned SS is sweeter than butter. Young buck learned, old man taught. You gotta know what you're welding together and what you got to use before you start the machine,, The weld is made between the ears of the man behind the mask long before the arc is struck. Learn all you can, and have a plan before you move.
I still have that book, don't have all the fancy rods in it we have today, don't have anything about MIG in it, or Heliarc but it's the most valuable book I own.
Posted: Wed Mar 07, 2018 6:01 am
by Datsun510
cj737 wrote:TIG welding can be done by mere mortals with some guidance, lots of practice, and more guidance along the way. Given your confession about your objectives and background, I think you'll be rather capable of getting 2 pieces of metal to stick together without risking someone's life needlessly.
I rent a two car garage as my workshop for my 510, so I need to clear with the landlord about adding 220V. If I get the green light and it's not too cost prohibitive I end up springing for it.
In the meantime I might get some steel welding practice in by build a welding cart and some end tables for my apartment, after I lay a mile or so of practice bead first :geek:
Posted: Wed Mar 07, 2018 6:05 am
by Datsun510
Franz© wrote:I was just busting your chops. I hear you, Franz.
That's a great story. What's the name of the book?
Posted: Wed Mar 07, 2018 8:01 am
Datsun510 wrote: Metals And How to Weld Them
