Hi everyone, first post.
I have a new Lincoln Square Wave 200 TIG machine and I just purchased Jody's Stubby gas lens kit for it.
The torch the Lincoln came with is a gray handled, flex head, PTA17.
When I watch the video that came with the gas lens kit, Jody removes the stock insulator off his torch and replaces it with the larger of the 2 provided insulators... then the rest of the pieces go on easily.
On my PTA17 torch, the larger stubby kit insulator doesn't seat on the little grooved "shelf" that the stock insulator seats on.
It barely covers the end of the torch body, and when I screw in the collet body, and the rest of the parts, it just doesn't seem right. Do I need a different shaped/sized insulator? I'm unsure if I should try it as is...
Thanks for the help!
I think the kit comes with two insulators. You just need to use which ever one fits the torch. I believe he provides two mainly to be accommodating for multiple torches. My Miller #17 uses the smaller of style insulators.
1. Take the whole torch apart.
2. Put the gas lens collet body on.
3. Try each insulator and put on a cup. If its snugs up real nice you probably have the correct one. If its fishy its probably wrong.
Good luck.
Good luck.
