TraditionalToolworks wrote:Oscar wrote:I agree most don't, even though two of my TIGs have AC stick welding functionality and adjustability. Can one get better results? Not really, just different results.
That's interesting, although I know you have a water cooled stick machine, don't you? That's interesting in itself.
Oscar wrote:If you were trying to weld very thin sheet metal, perhaps then it could help to narrow up the weld bead using a 1/16"/1.6mm stick electrode, by cranking up the AC frequency and adjusting the amperage as needed.
I actually have a few different types of 1/16" rods, they're kind of hard to find. I have 7018, 6011 and 6013 in 1/16", but I haven't used it too much other than just testing on some scraps. I like stick and it's a good skill to have under your belt. That TLP 200 you have looks like a nice box.
Alan
Yup, I have those same 1/16" 'rods', more like 'wires', lol. 5/64" E6013 are much more useful because they are typically shorter, so they don't whip/shake around as much when they are full length.
As for my DC Stick welder, it's not the machine that is water-cooled, its the stick stinger. I "invented" it about two years ago I think. Summer of 2018. Still works.
Really it's a normal, small stick stinger rated at 200A; the water cooled part is the power block adapter that I made that transmits the power just as a long, heavy gauge copper cable would, except it's light as a feather.
Milled and drilled to near-final shape
silver-soldered the power/water inlet & outlet, and capped the side holes
Tested before finalizing the setup
installed a full kevlar sleeve over the whole 50 foot length of cables
Ended up using the 50ft leather tig hose velcro cover, and installed a custom extended 50ft remote slider amperage control
That HTP DC stick welder is simply unbelievable how smooth yet crisp it delivers the arc! It's hard to explain in words, it's just one of those things that you have to use to see for yourself. One of the HTP rep's (who owns 3 or 4 Lincoln engine driven stick welders, Vantage 400's I believe) says that little lunch-box of a stick welder is
tied with his Lincoln engine drives for arc dynamics, crisp-ness, and smooth-ness. Of course those words are just that; it just has to be experienced. HTP's Instagram/facebook mentions that it will be on sale next month. They typically knock off $200 to $300 off the machine.
