Done some MIG and stick, but just getting started with TIG - focus on aluminum. Seems that prepping/cleaning is really important. Looking for advice on aluminum prep and cleaning products and techniques. ie. ??? wire wheels, flap wheels, (need stainless?), sand/grit papers, acetone or other cleaning chems, etc., etc.
Really depends on the alum your working with.
Brand new material that hasn't been through hell during storage you can get away with a stainless hand brush followed with a acetone wipe.
If we're talking dirty old aluminium that's been in service then the best I've found is.
Degrease before any abrasive/brush gets near it. Depending on contamination I either sand (for painted material etc) or use a power brush with a very very light touch.
Many companies make alum specific sanding wheels if I'm not mistaken. They're not a gimmick product like I once thought. They're worth every penny they charge for them.
Oh and something else I learned. If your sanding down alum to get a clean surface don't go much more aggressive than 80 grit.
80 grit seems to work on alum like 24 grit works on steel.
Any coarser than 80 and I find contamination just gets pushed and sealed into the alum so to speak.
as above new stuff doesn't need much of a clean.
i use flap disks, probably an 80 grit, however i use a variable speed grinder. slow it right down and it works extremely well. don't forget to clean up all the chips and dust as that will screw up your welds later on.
the other is carbide bits, especially for grooving out cracks.
