John107
    Thu Mar 07, 2024 9:40 am
Hello, I am welding 1/8” 5052 aluminum for work, we do a corner joint at 120-160 amps, pure 3/32” tungsten, 3/32” aluminum filler. we have a sister company doing the exact same boxes but their welds have a little wrinkle, or somewhat of a ripple looking bead in every dab instead of a smooth looking dime. I am wondering if it’s caused by an automatic wire feeder like a tip rig or some sort of robot?
What causes the wrinkles/ ripples in each dab?
Sister company with ripples
Myself with smooth dimes
tweake
    Mon Dec 18, 2017 4:53 am
    New Zealand
quite possibly using pulse which can give the fine ripples, but bigger dimes can be from doing double fill to build up the dime.
however i have also seen this look from double pulse mig.
Could be pulsed MIG, my money is on a different filler and less heat. The smoothed out beads look a bit hot while the stacked up bead looks like a different filler and a longer travel step to me. Both are good welds to the eye, it’s often just down to different people’s techniques.
