Tungsten size for thin wall SS tubing
Posted: Wed Apr 22, 2026 11:44 pm
by ekbmuts
Looking for opinions on this one.
If you were welding 3/8" OD, 0.035" wall SS tubing to another piece of tubing the same size and also welding it to 3/8" SS rod, would you use 3/32" tungsten or 1/16"?
Since I started TIG welding, I've believed that 3/32" tungsten is a one-size-fits-all but I'm just wondering if when I weld this tiny, thin material I should maybe be using 1/16". Would it make it easier?
Not a big deal. Just curious what your thoughts are.
Re: Tungsten size for thin wall SS tubing
Posted: Thu Apr 23, 2026 3:55 am
by tweake
for me 3/32 works just fine, i've done 0.030" with 3/32. imho the grind angle is more important.
there was a comment from someone that found 3/32 actually worked better. but i don't know the other details. you may find things like cup size and gas flow impacts it a bit as well.
also distance from work to tungsten makes a huge impact.
Posted: Thu Apr 23, 2026 11:04 am
by ekbmuts
Okay. So let's talk about grind angle. I tend to grind to a pencil point, long and sharp. But I'm not so sure that this gives me a tight, concentrated arc. What's your preference?
Posted: Fri Apr 24, 2026 2:13 am
by tweake
being an amateur tig welder, i'm all over the show. typically fairly blunt because my tungsten grinding setup doesn't do long fine grinds very well.
Posted: Fri Apr 24, 2026 2:15 pm
The sharper nd longer the taper on your tungsten, the higher up the tungsten the arc plume initiates. Tungsten size matters little in terms of thickness of material welding; it’s really only a consideration for amperage tolerance.
I’ve seen guys weld 0.06 thick wall titanium with a 1/8” tungsten. It’s all about comfort and skill. I use a 30* taper for nearly everything.
Posted: Fri May 01, 2026 11:52 pm
by ekbmuts
Out of curiosity, how exactly do you sharpen?
And what do you think about putting tungsten in a screw gun and rotating it while holding it against a bench grinder. And then polishing it off by rotating it on 120-grit and then 220-grit sandpaper?
Posted: Sat May 02, 2026 4:37 am
by tweake
if you have a drill that is aligned well enough. many people do that.
i typically use a cheap diamond knife sharpener. it has a decent wheel i can use. also trying out the cheap ones that fit onto a rotary tool. that works well but the diamond discs that came with it are terrible. finding replacements in the right size is a problem.
