MeatHead
    Fri Sep 23, 2011 5:34 am
Happy Holidays WeldingTipsandTricks community!
As the new year approaches, and my body reminds me I'm not getting younger, I wanted to open discussion about clamping system ideas for thin (~16 gauge / ~2mm) tacked-together-tube consisting of irregular curves / angles (like exhaust headers, etc). When I weld custom stainless steel exhaust systems (including headers, etc), I lose a lot of time and energy trying to re-position clamps (& magnets) for the tubing (Because it's not straight tube).
Has anyone tried using 2 flexible arm clamps that are strong enough to hold the weight of a welding hand resting on the tube, but not so strong that it prevents one to move and quickly turn the tube to continue the weld bead?
In my mind I was picturing those stainless steel flexible extenders used to hold microphones in any positions on mic stands. Sharing your ideas here would be very helpful and FUN! :mrgreen:
I do a lot of irregular fits on light-gauge SS pipe & tube.
Here's a tool designed for the job that may give you some ideas:
http://www.pipe-ltd.com/Products/PipeWo ... Range.aspx
I usually just improvise. I've got 11R Vise-Grip clamps w/ swivel feet I've welded 1" SS angle to. I've ground the centers of the legs back, so each angle functions like four fingers.
When space is tight, I use SS hose clamps, with bits of aluminum cut from cans as bridging.
I'm trying to visualize what you've described. There are times a simple gravity clamp would serve me well.
West Baden Iron
    Wed Nov 28, 2012 6:40 am
This isn't flexible but it does the same type of thing. You can buy these, but being a fabricator it seems easier just to make and you can make it fit what you need.
Hopefully it is ok to post a link to another welding forum.
http://weldingweb.com/showthread.php?t=48154
This isn't my thread on weldingweb but I'm in the process of making some of these. I'm modifying the bolt to tighten the joints with a t-handle to make adjustments quick and dirty. I'll post pictures when I get a little further along. I have about 10 projects I'm trying to complete that all make no money so it's hard to find time to complete them.
Thanks,
Jason
Lincoln Square Wave 175 Tig/Stick Miller Spectrum 375 Plasma
delraydella
    Mon Apr 25, 2011 7:35 pm
    Detroit, MI
West Baden/ Jason
I like those clamps, i might have to make some myself. Your plan to use a T-handle bolt is a good improvement. I can just picture the whole thing falling apart while you reach for a just out of reach wrench to tighten everything down. A cap head bolt could work here, too. There is enough of a knurl on the cap to give enough grip to finger tighten it for any minor adjustments.
I might try to make at least one of the rods be a telescopic one for a length adjustment,too.........
Other Steve
Landyman
    Tue Dec 18, 2012 7:44 pm
    Bromsgrove, England
What diameter pipe are you talking about?
Could you not use a big pair of 'mole' grips, or 'vice' grips, i don't know what they call them where you are, and clamp a spring loaded earth clamp to the handle?
Just make sure you get the ones with a curved jaw and not the straight ones.
This is what i mean
http://uk.images.search.yahoo.com/image ... =yfp-t-107
