$7 a bottle sure is cheaper than a $500 tungsten grinder
is it any good???
No, it will not remove contamination. I put mine in a drill and turning it as slow as I can hold it up to my bench grinder with a fine (dedicated) wheel on it. After that you can use the Chem Sharp but...It's not worth it IMHO.ksmrf wrote:so if your tungston is contaminated it wont get the gunk off? a
Theoretically you are supposed to break off any contam. If its just worn away, messed up it should work. but if theres a ball of filler or base metal, snap off.
- Marc Godwin
Hi Mickweldin mike 27 wrote:Theoretically you are supposed to break off any contam. If its just worn away, messed up it should work. but if theres a ball of filler or base metal, snap off.
I my low level experience if you just snap the tungsten off invariably you end up with split or cracks in your tungsten, better off to cut it.. Just my experience not saying it can't be done.
Marc. Aussie on the loose
kiwi2wheels
- kiwi2wheels
Just curious Mike, what brand are the Australian 2% you use ? Thanks.weldin mike 27 wrote:Australian thoriated ones (red) snap beautifully. Do it all the time.
kiwi
- Marc Godwin
Hi Mikeweldin mike 27 wrote:Australian thoriated ones (red) snap beautifully. Do it all the time.
What brand are they as I use Weldcraft exclusively and they certainly split and crack if you try to snap them off.. Not as bad as some Chinese makes I have used.
By experience, I agree breaking a tungsten cleanly is not as easy as you'd expect! However, I've a completely fail-safe solution: take your tungsten out and lay it on a steel surface plate with 5mm or so sticking over the edge... then hit the free end with quick vertical stroke of a hammer. It should break very cleanly.
Obviously you'll not be wanting to use your best surface plate! Fortunately it works just as well hanging the tungsten over the side of a vice jaw. I believe whatever you lay the tungsten on just needs to have a nice square edge and be hard enough not to distort any when beaten into submission with your hammer.
I've never tried Chemsharp, and after seeing the recent video, I doubt I ever will. It looks slow and thoroughly unpleasant. Five seconds on a belt linisher, rotating the tungsten by hand works for me. Any angle you want, striations in the correct direction, fast and free.
Cheers... Paul
Cheers... Paul
I get my best results snapping tungsten by holding the "keep" end in a vise or vice-grips while pinched between the fingers of old leather gloves. It absorbs the shock, and avoids breaks behind the clamping point.
Sorry, i should have been clearer, yes laying them on a table and a quick sharpblow. Ill try the gloves because they normally break into three or so clean pieces.
kiwi2wheels
- kiwi2wheels
- Marc Godwin
This is a fantastic video, but I do notice Jody never mentions anything about snapping the tungstens off?AKweldshop wrote:http://www.weldingtipsandtricks.com/sha ... rodes.html
I think this is a very interesting topic but one that there is no real answer other than what the manufacturers recommend. But we all know that does not always happen in the real world.
