Aluminum starting using 3/32" tungsten
Posted: Mon Feb 03, 2014 12:56 pm
by Infotig
Hello, I work for a company in the industry & would like to have your opinion on the following: How thin of a material (specifically Aluminum /AC Polarity) can you initiate a weld using 3/32" tungsten (Grey, Red) without distorting the material itself using the newer Inverter type of TIG technology out there? Thank you in advance for your feedback.
Re: Aluminum starting using 3/32" tungsten
Posted: Mon Feb 03, 2014 10:01 pm
by jimbob
I've welded plenty of beer cans with my inverter machine using a 3/32 sharpened to a sharp point. Biggest problem I've had is a getting some arc wander but that goes away at about 10-15 amps
Posted: Tue Feb 04, 2014 11:00 am
by Mike
Welcome to the forum infotig.
Posted: Thu Feb 06, 2014 9:50 am
by Infotig
Mike, Jim Bob, Thanks for the reply to my posting.
Jim Bob, you have me curious in regards to welding on pop cans using 3/32 " Tungsten. At what amperage are you welding at when you weld this? Also, do you ever have issues with the arc popping out on you in addition to the arc wandering issues you discussed.
Thanks for your post.
Posted: Tue Feb 11, 2014 10:33 pm
by jimbob
[quote="Infotig"]Mike, Jim Bob, Thanks for the reply to my posting.
I usually set my
machine at about 25-30 amps with the a/c freq. at 100- 120 depending which seems to work best for me that day.
. The a/c settings help control the arc wander. Also keeps the tungsten sharp, so low amp starts are more crisp
