first time doing this and very disappointed.
put the stinger on the positive side and the ground on the negative side
and as soon as i stomped the pedal my tungsten balled up huge. not only that smoked my glass lens and cracked it.
what did i do wrong?
chubbysautocenter
- chubbysautocenter
DC+ is only used for very thin aluminum.
The tungsten can't take that kind of heat - for example, 1/8" tungsten only handles about 40 amps on DC+
But on DC- it handles hundreds of amps.
- tungsten-electrode-chart.jpg (26.44 KiB) Viewed 1563 times
chubbysautocenter wrote:first time doing this and very disappointed.
Why would you try it???
What material where you attempting to weld?
Since this showed up in the "forum instructions", I'll migrate it to the TIG forum. I'll certainly get more views there.
chubbysautocenter
- chubbysautocenter
thanks that's great infoMinnesotaDave wrote:DC+ is only used for very thin aluminum.
I HATE BEING BI POLAR ITS GREAT
chubbysautocenter
- chubbysautocenter
just testing it out. it was mild steelAKweldshop wrote:Why would you try it???chubbysautocenter wrote:first time doing this and very disappointed.
Now you know, and you won't forget.chubbysautocenter wrote:just testing it out. it was mild steelAKweldshop wrote: Why would you try it???
Heat flows toward the positive conductor. In this case, it went from the steel into your tungsten.
Generalizations... The torch is negative for steel (aka DC- or DCEN [electrode negative]) and AC for aluminum. With aluminum, the positive swing (DCEP) on the AC cycle burns off the oxide layer, at the expense of heating your tungsten and reducing the heat that goes into the joint (which is one reason aluminum needs a beefier welder for the same thickness).
Cheers,
chubbysautocenter
- chubbysautocenter
RichardH wrote:Now you know, and you won't forget.chubbysautocenter wrote:just testing it out. it was mild steelAKweldshop wrote: Why would you try it???
What material where you attempting to weld?I learned it the same way.
Generalizations... The torch is negative for steel (aka DC- or DCEN [electrode negative]) and AC for aluminum. With aluminum, the positive swing (DCEP) on the AC cycle burns off the oxide layer, at the expense of heating your tungsten and reducing the heat that goes into the joint (which is one reason aluminum needs a beefier welder for the same thickness). great info thanks
Cheers,
