- GreinTime
When you weld for long periods of time or long weld beads. You can increase the amperage rating of a torch because the water provides the cooling as opposed to the argon.
Welding aluminum requires more amps, plus AC heats up the torch more.mobile1 wrote:When is a water-cooled torch used with TIG welding?
So once you start doing a lot of aluminum over 1/8" it's time for a water cooled torch.
I've ruined several torches and am now going water cooled.
Bill Beauregard
- Bill Beauregard
Water cooled torches take advantage of the return flow of coolant to limit the temperature of the torch lead. Copper is heavy! A smaller wire does the job if kept cool. Water cooled torches are smaller, weigh less, and you may not need as heavy a glove. The down side is noise from the cooler.
